Amit585731
Jun 12, 2015Adding encrypted key to F5
Hi All,
We are migrating our config from cisco ace to F5 so we are migrating cert and keys. We are seeing one issue where key is encrypted with passphrase and unfortunately no one knows what was passphrase set while adding key on cisco ace. Is there any way I can import these keys on F5.
Thanks for help in advance.
Thanks.
- nitass
Employee
is private key encrypted indeed? have you checked file content (e.g. cat file)?
if it is encrypted, i am afraid you need passphrase.
