Active Directory with APM.
We set up an authentication flow from radius to Active Directory with APM.
Are there any problems that could occur if two terminals connect to the VPN at the same time using a single Active Directory account?
- PeteWhite
Employee
the short answer is no - though it is a very open-ended question. Do you see any problems? Are you thinking of any specific problems?
- h_H
Thank you for your response.
We performed the same verification in a test environment and found that one of the terminals was denied by the access policy and could not access the VPN.
Since it is not always denied and sometimes it is possible to connect to the VPN normally, we thought that the problem might be that the Active Directory accounts are the same.
- PeteWhite
Employee
check the APM profile settings
- h_H
I checked and the settings are the same as in the attached image.
Max Session Per User 0
Max In Progress Sessions Per Client IP 128
