18-Dec-2022 21:54 - edited 18-Dec-2022 21:55
Hello,
When I went to check the throughput of F5, I found a lot of information as shown in the figure below :
I tried to understand through the official F5 link below, but there are still a few questions I would like to ask
https://support.f5.com/csp/article/K50309321
1. If I just look at the throughput of the client coming in to F5, the service value and In value of Throughput is not there, right? Should I be looking at the file with the In values for the TMM client?
2. What is the meaning of multiplying 8 within the formula? Why is it multiplied by 8 ?
3. I see are per second capture value, but the above has current time, interval how to bring into the formula to calculate the?
Any help is appreciate.
18-Dec-2022 22:37
1. That article is pretty good at explaining.
The traffic flow from a client is seen as In to a virtual server and In to a server. Likewise, the response from the server is seen as Out from the server and Out from the virtual server.
Client IN -> Server IN
Client Out <- Server Out
2. Because the counters are in bytes example sysStatClientBytesOut , to convert it to bits , it is multiplied by 8. Because a byte has 8 bits
3. The counters have predefined intervals , like this for example:
sysStatClientBytesOut1m
sysStatClientBytesOut5s
sysStatClientBytesOut5m
18-Dec-2022 22:53
Hi mihaic,
Thanks for your reply.
About the counters have predefined intervals,
What is <interval> value in "tmsh show sys performance throughput detail" ?
19-Dec-2022 01:45
Hi mihaic,
I found Throughput In is [<Clients bits in> + <Server bits Out>]
However, I found that according to the data on the table, there is a big difference in adding up to each other ...
( 15.3k + 7.9k = 208.1 k ... ? )
18-Dec-2022 23:39
Hi mihaic,
So Current's interval is 1 ... ?
19-Dec-2022 02:06
Hi mihaic,
But why does the picture show 208.1K...
19-Dec-2022 02:10
well it is written in that article.
The total throughput in and out of the BIG-IP system collected from all interfaces, including traffic processed by all Traffic Management Microkernel (TMM) and Packet Velocity ASIC (PVA)
In : means total ingress traffic on all interfaces except management.
19-Dec-2022 02:21
Hi mihaic,
yeah...But my F5 is VE version...
So there should be no need to take into account the PVA piece...
It looks like TMM Client-side throughput already has the sum of all traffic...
So it should be 28.2 K, but it is showing 208.1 K...
19-Dec-2022 02:38
You are comparing the value of 208 K which is all ingress traffic on all interfaces
with a Value of 28K that something IN and something OUT.
What are you trying to do? I don't think adding things will give you something that you'll expect.
That's because of different things that affect the throughput. See below.
Have a look at the number of packets IN and packets OUT. You will see that you have more than twice the number of packets coming in than going out.
I don't think it works that way. you have throughput in and throughput out.
Also be aware of different options that affect the throughput, like oneconnect, HTTP cache, compression, irules
https://support.f5.com/csp/article/K9077
