Technical Forum
About cmd change partition setting
young19918
Altocumulus
Altocumulus
Hello,
Is there any way to change the settings of the following links using the cmd method?
https://my.f5.com/manage/s/article/K40411315
Any help is appreciate.
1 ACCEPTED SOLUTION
Hi young19918,
After creating the partition, you can change redundant device configuration from "sys folder".
modify sys folder /K8s traffic-group testtrafficgroup
"inherited-devicegroup" and "inherited-traffic-group" are read-only properties. You can change them from bigip_base.conf file.
https://clouddocs.f5.com/cli/tmsh-reference/v15/modules/sys/sys_folder.html
https://my.f5.com/manage/s/article/K08114320
1 REPLY 1
Hi young19918,
