Christopher_Mor's avatar
Christopher_Mor
Dec 15, 2019
500: java.lang.IllegalArgumentException importing SSM and ASM into BigIQ
Sorry that this is probably a dumb question, but I need help
This is a clean installation (lab setup) of both BigIQ (7.0.0.1-0.0.6) and BigIP (15.0.1 Build 0.0.11)
ASM is enabled and provisioned in the BigIP, and it is discovered by the BigIQ, but import fails with:
"Coordinator failed during working-config update, roll-back working-config started; reason: Worker http://localhost:8100/cm/security-shared/working-config/log-profiles failed validation with status 500: java.lang.IllegalArgumentException: At least one log profile must be set as templates default."
What template am I supposed to be setting and where? I expect it is documented, but I can't locate the information
Thanks in advance,
  • I believe this is a bug between these two versions of SW. Please open a case with support to confirm.
