Verified Design: SSL Orchestrator with McAfee Web Gateway-Part 1
Summary
This article is part of a series on implementing Orchestrated Infrastructure Security. It includes High Availability and the protection of critical assets using McAfee Web Gateway.  It is assumed that SSL Orchestrator is already deployed, and basic network connectivity is working.
If you need help setting up SSL Orchestrator for the first time, refer to the Dev/Central article series on Implementing SSL Orchestrator here or the CloudDocs Deployment Guide here.
This article focuses on using SSL Orchestrator as a tool to assist with simplifying Change Management processes, procedures and shortening the duration of the entire process.
Configuration files of McAfee Web Gateway can be downloaded from here from GitLab.
Please forgive me for using SSL and TLS interchangeably in this article.
A video demo of this Dev/Central article is available HERE
This article is divided into the following high level sections:
Part1 (Available here)
  • Configure McAfee Web Gateway (MWG) interfaces
  • Create a new Topology to perform testing
  • Monitor McAfee Web Gateway statistics – change the weight ratio – check McAfee Web Gateway stats again
  • Remove a single McAfee Web Gateway device from the Service
Part 2 (Available here)
  • Perform maintenance on the McAfee Web Gateway device
  • Add the McAfee Web Gateway device to the new Topology
  • Test functionality with a single client
  • Add the McAfee Web Gateway device back to the original Topology
  • Test functionality again
  • Repeat to perform maintenance on the other McAfee Web Gateway device
From the MWG UI navigate to Configuration > Appliances > Proxies.  Under Network Setup select Transparent bridge.
Click Save Changes on the top right
Navigate to Network interfaces. In this example eth2 and eth3 will be used to create the Transparent bridge. Both interfaces need to be enabled and the IP settings must be disabled for IPv4 and IPv6.
On the Advanced tab enable the bridge and give it a name, ibr0 in this example. Do this for both interfaces.
Save changes
Check ibr0 and set it to enabled.  Disable IPv4 and IPv6
Click Save Changes
Note: complete these steps on the 2nd McAfee Web Gateway
Note: when configuring for High Availability you will need to create a 2nd Transparent bridge
Please contact McAfee for assistance if needed
A new Topology will be used to safely test the Service after maintenance is performed.  The Topology should be similar to the one used for production traffic.  This Topology can be re-used in the future.
From the BIG-IP Configuration Utility select SSL Orchestrator > Configuration.  Click Add under Topologies.
Scroll to the bottom of the next screen and click Next.
Give it a name, Topology_Staging in this example.
Select L2 Outbound as the Topology type then click Save & Next.
For the SSL Configurations you can leave the default settings.  Click Save & Next at the bottom.
Click Save & Next at the bottom of the Services List.
Click the Add button under Services Chain List.  A new Service Chain is needed so we can remove McAfee Web Gateway from the Production Service and add it here.
Give the Service Chain a name, Staging_Chain in this example.  Click Save at the bottom.
Note: The Service will be added to this Service Chain later.
Click Save & Next
Click the Add button on the right to add a new rule.
For Conditions select Client IP Subnet Match.
Enter the Client IP and mask, 10.5.9.51/32 in this example.  Click New to add the IP/Subnet.
Set the SSL Proxy Action to Intercept.
Set the Service Chain to the one created previously.
Click OK.
Note: This rule is written so that a single client computer (10.5.9.51) will match and can be used for testing.  In the All Traffic default rule set the SSL Proxy Action to Bypass.
Select Save & Next at the bottom.
For the Interception Rule set the Source Address to 10.5.9.51/32.  Set the Destination Address/Mask to 10.4.11.0/24.  Set the port to 443.
Select the VLAN for your Ingress Network and move it to Selected.
Set the L7 Profile to Common/http.
Click Save & Next.
For Log Settings, scroll to the bottom and select Save & Next.
Click Deploy.
Monitor McAfee Web Gateway statistics – change the weight ratio – check McAfee Web Gateway statistics again
Check the statistics on the McAfee Web Gateway device we will be performing maintenance on.  It’s “MWG1” in this example. One way to do this is with a packet trace. From the McAfee Web Gateway UI go to Troubleshooting > Packet tracing. I set the Command line parameters to “-I ibr0” which will capture all packets on the bridge interface.
Note: This McAfee Web Gateway device is actively processing connections. Note the connections are in clear text, HTTP on port 80. SSL Orchestrator decrypted the SSL/TLS and sent it to the McAfee device for inspection.
Change the Weight Ratio
Back to the SSL Orchestrator Configuration Utility.  Click SSL Orchestrator > Configuration > Services > then the Service name, ssloS_McAfeeWebGateway in this example.
Click the pencil icon to edit the Service.
Click the pencil icon to edit the Network Configuration for MWG2
Set the ratio to 65535 and click Done.
Click OK if presented with the following warning.
Click Deploy.
Click OK when presented with the Success message.
Check McAfee Web Gateway Statistics Again
Check the statistics on the McAfee Web Gateway device again. It’s “MWG1” in this example.  From the McAfee Web Gateway UI go to Troubleshooting > Packet tracing.  I set the Command line parameters to “-I ibr0” which will capture all packets on the bridge interface.
It should look like the following:
Note: The connections above represent the health checks from SSL Orchestrator to the inline Service. Therefore, this McAfee Web Gateway is not actively processing connections.
Under Network Configuration, delete MWG1.
Click Deploy.
Click HERE for Part 2 of the article
Related Articles
Integrating SSL Orchestrator with McAfee Web Gateway-Explicit Proxy
Updated 2 years ago
Version 4.0
