Lightboard Lessons: What is BIG-IP APM?
In this Lightboard, I light up some lessons on BIG-IP Access Policy Manager. BIG-IP APM provides granular access controls to discreet applications and networks supporting 2FA and federated identity management. You can also check out Chase's written article What is BIG-IP APM?
ps
Resources
Published Jul 26, 2017
2 Comments
  • Hi ! can i have a help on this qstn ? pls
    in which scenario should an administrator use a full tunnel vpn solution ?
    • when users only access web applications ?
    • when users need access multiple networks services ?
    • when users need remote access to email ?
    • when users require access to a terminal server ?
  • PSilva's avatar
    PSilva
    Ret. Employee
    Hi~ Hope this helps.
    when users only access web applications ? (you could or use portal access/SAML/SSO)
    when users need access multiple networks services ? (you could depending on services needed)
    when users need remote access to email ? (depends since you can config owa or apptunnel for email)
    when users require access to a terminal server ? (depends but I think there is a TermServer template on APM)
    ps
