on
06-Jun-2023
05:00
- edited on
12-Jun-2023
13:15
by
Rebecca_Moloney
SSL Orchestrator centralizes & manages decryption of SSL/TLS traffic. This enables security and monitoring tools to view the decrypted content and analyze it for threats and other anomalies. SSL Orchestrator removes the burden of decrypting content from your security tools so they perform better and are more scalable.
An integrated F5 and McAfee Web Gateway solution eliminates the blind spots introduced by SSL/TLS encrypted content.
This article assumes you have SSL Orchestrator configured with a Topology and Service Chain
Configure the Transparent Web Proxy as follows and click the plus sign under Port Redirects
Set the Destination proxy port to 80 and click OK
Click Save Changes
Configure the Network Interfaces as follows
Specify the IP address and mask to be used for eth2, 10.0.0.55 255.255.255.0 in this example.
Specify the IP address and mask to be used for eth3, 10.1.1.5 255.255.255.0 in this example.
The Default Gateway will be a Self IP address on SSL Orchestrator, 10.1.1.1 in this example.
Note: in this example SSL Orchestrator is deployed with an L3 Outbound Topology. That’s what the other two Self IPs are for. Your configuration will look different if using an L2 Topology.
This article assumes you have SSL Orchestrator configured with a Topology and Service Chain.
Navigate to SSL Orchestrator > Configuration
Under Services, click Add.
In the Service Catalog select the Inline HTTP tab then double click on McAfee Web Gateway HTTP Proxy.
Give it a name, MWG in this example.
Under Service Definition unselect the option to Auto Manage Addresses.
Set the Proxy Type to Transparent
For the To Service VLAN select 10.0.0.1 (VLAN 10.0.0.0).
Click Add for HTTP Proxy Devices.
Enter the MWG IP address, 10.0.0.55 in this example. Click Done.
For the From Service VLAN select 10.1.1.1 (VLAN 10.1.1.0)
Enable Port Remap. Set the Remap Port to 80.
Set Manage SNAT Settings to Auto Map
Click Save & Next at the bottom.
Click the name of the Service Chain.
Select the MWG Service from the left and click the arrow to move it to the right. Click Save.
Click OK
Click Deploy
Click OK to the Success message.
When done it should look like the following:
From the Services screen if you expand the Pool Member Status you should see the McAfee Web Gateway
In this example there is a Windows client that connects through the SSL Orchestrator to a Windows server running the following web site:
Test this connection now and it should look like the following:
In this example the MWG is configured with a Custom Category to block connections to http://10.4.11.99. When attempting to connect to this site with a web browser you should see a block page like the following:
This completes configuration of BIG-IP SSL Orchestrator with McAfee Web Gateway. At this point traffic that flows through SSL Orchestrator will be decrypted and sent to the MWG Service and inspected for malicious payloads or policy violations.
