Technical Articles
F5 SMEs share good practice.
Lori_MacVittie
F5 Employee
F5 Employee
 Migration is not going to happen overnight and it’s going to require simultaneous support for both IPv4 and IPv6 until both sides of the equation are ready.
0151T000003d8SQQAY.png Making the switch from IPv4 to IPv6 is not a task anyone with any significant investment in infrastructure wants to undertake. The reliance on IP addresses of infrastructure to control, secure, route, and track everything from simple network housekeeping to complying with complex governmental regulations makes it difficult to simply “flick a switch” and move from the old form of addressing (IPv4) to the new (IPv6). This reliance is spread up and down the network stack, and spans not only infrastructure but the very processes that keep data centers running smoothly. Firewall rules, ACLs, scripts that automate mundane tasks, routing from layer 2 to layer 7, and application architecture are likely to communicate using IPv4 addresses. Clients, too, may not be ready depending on their age and operating system, which makes a simple “cut over” strategy impossible or, at best, fraught with the potential for techncial support and business challenges.
IT’S NOT JUST SIZE THAT MATTERS
The differences between IPv4 and IPv6 in addressing are probably the most visible and oft referenced change, as it is the length of the IPv6 address that dramatically expands the available pool of IP addresses and thus is of the most interest. IPv4 IP addresses are 32-bits long while IPv6 addresses are 128-bits long. But IPv6 addresses can (and do) interoperate with IPv4 addresses, through a variety of methods that allow IPv6 to carry along IPv4 addresses. This is achieved through the use of IPv4 mapped IPV6 addresses and IPv4 compatible IPv6 addresses. This allows IPv4 addresses to be represented in IPv6 addresses.
Comments
JRahm
Community Manager
Community Manager
IP::addr and IPv6
Lori_MacVittie
F5 Employee
F5 Employee
F5 Friday: Thanks for calling... please press 1 for IPv6 or 2 for IPv4.
Version history
Last update:
‎04-Feb-2011 01:44
Updated by:
Contributors
