Technical Articles
F5 SMEs share good practice.
Nicolas_Menant
F5 Employee
F5 Employee
In our previous article, we have setup Kubernetes and calico with our BIG-IPs. Now we will setup F5 Container Ingress Services (F5 CIS) and deploy an ingress service.
Note: in this deployment, we will setup F5 CIS in the namespace kube-system
BIG-IPs Setup
Setup our Kubernetes partition
Before deploying F5 Container Ingress Services, we need to setup our BIG-IPs:
  • Setup a partition that CIS will use.
  • Install AS3
On EACH BIG-IP, you need to do the following:
In the GUI, go to System > User > Partitions List and click on the Create button
Create a partition called "kubernetes" and click Finished
Next we need to download the AS3 extension and install it on each BIG-IP.
Install AS3
Go to GitHub . Select the release with the "latest" tag and download the rpm.
Once you have the rpm, go to iApps > Package Management LX and click the Import button (you need to run BIG-IP v12.1 or later) on EACH BIG-IP
Chose your rpm and click Upload. Once the rpm has been uploaded and loaded, you should see this:
Our BIG-IPs are setup properly now.
Next, we will deploy F5 CIS
CIS Deployment
Connect to your Kubernetes cluster. We will need to setup the following:
  • Create a Kubernetes secret to store our BIG-IPs credentials
  • Setup a service account for CIS and setup RBAC
  • Setup our CIS configuration. We will need 1xCIS per BIG-IP (even when BIG-IP is setup as a cluster - we don't recommend automatic sync between BIG-IPs)
  • Deploy one CIS per BIG-IP
Store our BIG-IP credentials in a kubernetes secret
To store your credentials (login/password) in a kubernetes secret, you can run the following command (https://clouddocs.f5.com/containers/v2/kubernetes/kctlr-secrets.html#secret-bigip-login😞
kubectl create secret generic bigip-login --namespace kube-system --from-literal=username=<your_login> --from-literal=password=<your_password>
In my setup, my credentials are the following:
  • Login: admin
  • Password: D3f4ult123
So we'll run the following command:
kubectl create secret generic bigip-login --namespace kube-system --from-literal=username=admin --from-literal=password=D3f4ult123
ubuntu@ip-10-1-1-4:~$ kubectl create secret generic bigip-login --namespace kube-system --from-literal=username=admin --from-literal=password=D3f4ult123
secret/bigip-login created
Create a Service Account /RBAC for CIS
Now we need to create our service account (https://clouddocs.f5.com/containers/v2/kubernetes/kctlr-app-install.html#set-up-rbac-authentication😞
Run the following command: :
kubectl create serviceaccount bigip-ctlr -n kube-system
ubuntu@ip-10-1-1-4:~$ kubectl create serviceaccount bigip-ctlr -n kube-system
serviceaccount/bigip-ctlr created
Use your favorite editor to create this file:
f5-k8s-sample-rbac.yaml:
# for use in k8s clusters only
 # for OpenShift, use the OpenShift-specific examples
 kind: ClusterRole
 apiVersion: rbac.authorization.k8s.io/v1
 metadata:
 rules:
 - apiGroups: ["", "extensions"]
  resources: ["nodes", "services", "endpoints", "namespaces", "ingresses", "pods"]
  verbs: ["get", "list", "watch"]
  resources: ["configmaps", "events", "ingresses/status"]
  verbs: ["get", "list", "watch", "update", "create", "patch"]
  resources: ["secrets"]
  resourceNames: ["<secret-containing-bigip-login>"]
kind: ClusterRoleBinding
 metadata:
  namespace: kube-system
 roleRef:
  apiGroup: rbac.authorization.k8s.io
  kind: ClusterRole
 subjects:
 - apiGroup: ""
  kind: ServiceAccount
Deploy this config by running the following command:
kubectl apply -f f5-k8s-sample-rbac.yaml
ubuntu@ip-10-1-1-4:~$ kubectl apply -f f5-k8s-sample-rbac.yaml
clusterrole.rbac.authorization.k8s.io/bigip-ctlr-clusterrole created
clusterrolebinding.rbac.authorization.k8s.io/bigip-ctlr-clusterrole-binding created
Next step is to setup our CIS deployment files
Create our CIS deployment configurations
Use your favorite editor to create the following files:
setup_cis_bigip1.yaml:
apiVersion: apps/v1
kind: Deployment
metadata:
spec:
 selector:
   matchLabels:
     app: k8s-bigip1-ctlr
 # DO NOT INCREASE REPLICA COUNT
 replicas: 1
 template:
   metadata:
     labels:
   spec:
     # Name of the Service Account bound to a Cluster Role with the required
     # permissions
     serviceAccountName: bigip-ctlr
     containers:
       - name: k8s-bigip-ctlr
         image: "f5networks/k8s-bigip-ctlr"
         env:
           - name: BIGIP_USERNAME
             valueFrom:
               secretKeyRef:
                 # Replace with the name of the Secret containing your login
                 # credentials
                 key: username
           - name: BIGIP_PASSWORD
             valueFrom:
               secretKeyRef:
                 # credentials
                 key: password
         command: ["/app/bin/k8s-bigip-ctlr"]
         args: [
           # See the k8s-bigip-ctlr documentation for information about
           # all config options
           # https://clouddocs.f5.com/products/connectors/k8s-bigip-ctlr/latest
           "--bigip-username=$(BIGIP_USERNAME)",
           "--bigip-password=$(BIGIP_PASSWORD)",
           "--bigip-url=10.1.20.11",
           "--bigip-partition=kubernetes",
           "--insecure=true",
           "--pool-member-type=cluster",
           "--agent=as3"
     imagePullSecrets:
       # Secret that gives access to a private docker registry
       - name: f5-docker-images
       # Secret containing the BIG-IP system login credentials
       - name: bigip-login
setup_cis_bigip2.yaml:
apiVersion: apps/v1
kind: Deployment
metadata:
spec:
 selector:
   matchLabels:
     app: k8s-bigip2-ctlr
 replicas: 1
 template:
   metadata:
     labels:
   spec:
     # permissions
     containers:
         env:
             valueFrom:
               secretKeyRef:
                 # credentials
                 key: username
             valueFrom:
               secretKeyRef:
                 # credentials
                 key: password
         args: [
           "--bigip-url=10.1.20.12",
           "--insecure=true",
           "--agent=as3"
     imagePullSecrets:
       - name: bigip-login
To deploy our CIS, run the following commands:
kubectl apply -f setup_cis_bigip1.yaml
kubectl apply -f setup_cis_bigip2.yaml
You can make sure that they got deployed successfully:
kubectl get pods -n kube-system
You can review if it launched successfully with the commands:
kubectl logs <pod_name> -n kube system
ubuntu@ip-10-1-1-4:~$ kubectl logs k8s-bigip2-ctlr-deployment-6f674c8d58-bbzqv -n kube-system
2020/01/03 12:04:06 [INFO] Starting: Version: 1.12.0, BuildInfo: n2050-623590021
2020/01/03 12:04:06 [INFO] ConfigWriter started: 0xc0002bb950
2020/01/03 12:04:06 [INFO] Started config driver sub-process at pid: 14
2020/01/03 12:04:07 [INFO] NodePoller (0xc000b7c090) registering new listener: 0x11bfea0
2020/01/03 12:04:07 [INFO] NodePoller started: (0xc000b7c090)
2020/01/03 12:04:07 [INFO] Watching Ingress resources.
2020/01/03 12:04:07 [INFO] Watching ConfigMap resources.
2020/01/03 12:04:07 [INFO] Handling ConfigMap resource events.
2020/01/03 12:04:07 [INFO] Handling Ingress resource events.
2020/01/03 12:04:07 [INFO] Registered BigIP Metrics
2020/01/03 12:04:07 [INFO] [2020-01-03 12:04:07,663 __main__ INFO] entering inotify loop to watch /tmp/k8s-bigip-ctlr.config563475778/config.json
2020/01/03 12:04:08 [INFO] Successfully Sent the FDB Records
You may also check your BIG-IPs configuration: if CIS has been able to connect successfully, it will have created *another* partition called "kubernetes_AS3".This is explained here: https://clouddocs.f5.com/containers/v2/kubernetes/kctlr-use-as3-backend.html
CIS will create partition kubernetes_AS3 to store LTM objects such as pools, and virtual servers. FDB, and Static ARP entries are stored in kubernetes. These partitions should not be managed manually.
Application Deployment
In this section, we will do the following:
  • Deploy an application with 2 replicas (ie 2 instances of our app)
  • Setup an ingress service to connect to your application
Deploy our application and service
Create the following service and deployment configuration files:
f5-hello-world-app-http-deployment.yaml
apiVersion: apps/v1
kind: Deployment
metadata:
 namespace: default
spec:
 replicas: 2
 selector:
   matchLabels:
     app: f5-hello-world
 template:
   metadata:
     labels:
       app: f5-hello-world
   spec:
     containers:
     - env:
       - name: service_name
         value: f5-hello-world
       image: f5devcentral/f5-hello-world:latest
       imagePullPolicy: Always
       ports:
       - containerPort: 8080
         protocol: TCP
f5-hello-world-app-http-service.yaml
apiVersion: v1
kind: Service
metadata:
 namespace: default
 labels:
   app: f5-hello-world
spec:
 ports:
 - name: f5-hello-world
   port: 8080
   protocol: TCP
   targetPort: 8080
 type: NodePort
 selector:
   app: f5-hello-world
Apply your deployment and service:
kubectl apply -f f5-hello-world-app-http-deployment.yaml
kubectl apply -f f5-hello-world-app-http-service.yaml
ubuntu@ip-10-1-1-4:~$ kubectl apply -f f5-hello-world-app-http-deployment.yaml
deployment.apps/f5-hello-world created
ubuntu@ip-10-1-1-4:~$ kubectl apply -f f5-hello-world-app-http-service.yaml
service/f5-hello-world created
You can review your deployment and service with kubectl get :
ubuntu@ip-10-1-1-4:~$ kubectl get pods
NAME                             READY  STATUS   RESTARTS  AGE
f5-hello-world-847698f5c6-59mmn  1/1    Running  0         2m3s
f5-hello-world-847698f5c6-pcz9v  1/1    Running  0         2m3s
ubuntu@ip-10-1-1-4:~$ kubectl get svc
NAME            TYPE       CLUSTER-IP    EXTERNAL-IP  PORT(S)         AGE
f5-hello-world  NodePort   10.97.83.208  <none>       8080:31380/TCP  2m
kubernetes      ClusterIP  10.96.0.1     <none>       443/TCP         63d
Define our ingress service
CIS ingress annotations can be reviewed here: https://clouddocs.f5.com/products/connectors/k8s-bigip-ctlr/v1.11/#ingress-resources
Create the following file:
f5-as3-ingress.yaml:
apiVersion: extensions/v1beta1
kind: Ingress
metadata:
 namespace: default
 annotations:
 # all Ingress Annotations
 # https://clouddocs.f5.com/products/connectors/k8s-bigip-ctlr/latest/#supported-ingress-annotations
   virtual-server.f5.com/ip: "10.1.10.80"
   virtual-server.f5.com/http-port: "443"
   virtual-server.f5.com/partition: "kubernetes_AS3"
   virtual-server.f5.com/health: '[{"path": "/", "send": "HTTP GET /", "interval": 5, "timeout": 10}]'
spec:
 backend:
   # The name of the Service you want to expose to external traffic
   serviceName: f5-hello-world
   servicePort: 8080
you can review the BIG-IP configuration by going into the kubernetes_AS3 partition
Summary
In this article we saw how to deploy CIS with AS3 to handle ingress services.
CIS has more capabilities than ingress that you may review here: https://clouddocs.f5.com/containers/v2/kubernetes/ (configmap, routes, …)
Relevant links to this article:
Version history
Last update:
‎20-Jan-2020 09:53
Updated by:
Contributors
