on 20-Mar-2019 04:00
Following up my article Authenticating Kubernetes I want to show you the completed and running environment. Here is a demonstration of the Kubernetes API/Dashboard authentication with BIG-IP BIG-IP using mTLS, Basic Auth (Username/Password), and OAuth Tokens. This illustrates how BIG-IP Access Policy Manager (APM) can securely authenticate to Kubernetes using multiple methods and capture audit logs via BIG-IP Application Security Manager (ASM). As always, please let us know if you have questions.
This is great! Can you supply the code / examples from both the API protection as well as the per-session policy flows? Maybe as a PDF attachment?
