AskF5's new BIG-IP upgrade guide
AskF5 published the new BIG-IP upgrade guide to help you through the BIG-IP upgrade process. At a minimum, F5 recommends that you upgrade your BIG-IP appliances to at least version 14.1.x and your BIG-IP VE systems to at least version 15.1.x. Because F5 customers use a variety of configurations and tools, there are many upgrade scenarios.
In this new Operations Guide, you'll find the following topics:
Prepare to upgrade
BIG-IP hardware and VE platforms
BIG-IP systems
VIPRION BIG-IP systems
Other BIG-IP vCMP systems
BIG-IP cloud platforms
BIG-IP on AWS
BIG-IP on Microsoft Azure
BIG-IP on GCP
Automation
Send Feedback
This guide is a work in progress; request the upgrade scenarios you want to see in this guide. Use the feedback or survey button at the bottom of any guide page, or email TellAskF5@f5.com.
For supported paths and general considerations, refer to K13845: Overview of supported BIG-IP upgrade paths and an upgrade planning reference.
Updated Feb 07, 2022
Version 2.0
