Technical Articles
F5 SMEs share good practice.
Graham_Alderso1
F5 Employee
F5 Employee
Learn how to use the F5 Advanced Web Application Firewall to easily lock down your applications so that bots can’t attack your mobile APIs. Integrating an SDK can be challenging, but this video will show you the quick way to add anti-bot and other protections directly into your mobile app.
See the entire AppSec Made Easy series.
Comments
Jan_Sysmans_361
Great video Graham.
DFSprint_363726
Great concept. Is there something similar we can do for web/websites that consume open APIs on the web? Thanks.
BAMcHenry
F5 Employee
F5 Employee
@DFSprint, we are actively developing API security features to be available with Advanced WAF in the future. Making a similar integration available for open APIs is a somewhat more challenging use case, but we are exploring possibilities.
Version history
Last update:
‎07-May-2018 04:00
Updated by:
Contributors
