Technical Articles
F5 SMEs share good practice.
Custom Alert Banner
PSilva
Legacy Employee
Legacy Employee
Reliable access to mission-critical applications is a key success factor for enterprises. For many organizations, moving applications from physical data centers to the cloud can increase resource capacity and ensure availability while reducing system management and IT infrastructure costs. Achieving this hybrid data center model the right way requires healthy resource pools and the means to distribute them. The F5 Application Availability Between Hybrid Data Centers solution provides core load-balancing, DNS and acceleration services that result in non-disruptive, seamless migration between private and public cloud environments.
Check out the new Reference Architecture today along with a new video below!
ps
Related:
Connect with Peter: Connect with F5:
0151T000003d5QFQAY.png 0151T000003d5IpQAI.png 0151T000003d5QIQAY.png  0151T000003d5QHQAY.png 0151T000003d5QIQAY.png 0151T000003d5QLQAY.png 0151T000003d5QMQAY.png
Version history
Last update:
‎20-Jan-2015 10:19
Updated by:
Contributors
