2021 OWASP Top Ten Lightboard Series
What is the OWASP Top Ten and how is the list compiled? Well, John Wagnon created a new 2021 Lightboard Series to answer just that! He starts with an explanation of the OWASP Top Ten and how the list is made and then does a separate video for each of the Top Ten! Watch the Playlist below! #OWASPTOP10
Here's the list for 2021:
A1. Broken Access Control - Coming in at number one and moving up from the fifth position from the 2017 list, 94% of tested applications were shown to have some form of broken access control. Notable Common Weakness Enumerations (CWEs) included are CWE-200: Exposure of Sensitive Information to an Unauthorized Actor, CWE-201: Exposure of Sensitive Information Through Sent Data, and CWE-352: Cross-Site Request Forgery.
A2. Cryptographic Failures - Shifting up one position from the 2017 list to Number 2 is Cryptographic Failures. This was previously known as "Sensitive Data Exposure" which is more of a broad symptom rather than a root cause, and the focus is on failures related to cryptography (or lack thereof). This can often lead to exposure of sensitive data. Notable Common Weakness Enumerations (CWEs) included are CWE-259: Use of Hard-coded Password, CWE-327: Broken or Risky Crypto Algorithm, and CWE-331 Insufficient Entropy.
A3. Injection - Injection attacks move down from the #1 spot on the 2017 list to the #3 spot on the 2021 list. Injection attacks refer to a broad class of attack vectors (not just SQL). In an injection attack, an attacker sends untrusted input to an application. This input gets processed by an interpreter as part of a command or query. In turn, this alters the execution of that program. Injections are among the oldest and most dangerous attacks aimed at web applications. They can lead to data theft, data loss, loss of data integrity, denial of service, as well as full system compromise.
A4. Insecure Design - Insecure design is a broad category representing different weaknesses, expressed as “missing or ineffective control design.” Insecure design is not the source for all other Top 10 risk categories. There is a difference between insecure design and insecure implementation. We differentiate between design flaws and implementation defects for a reason, they have different root causes and remediation. A secure design can still have implementation defects leading to vulnerabilities that may be exploited. An insecure design cannot be fixed by a perfect implementation as by definition, needed security controls were never created to defend against specific attacks.
A5. Security Misconfiguration - Security Misconfiguration happens when you fail to implement all the security controls for a server or web application, or implement the security controls, but with errors. This security risk moves up from the #6 spot on the 2017 list. John explains the importance of proper security configuration and gives some examples of what to do and what to avoid.
A6. Vulnerable and Outdated Components - This risk was #9 on the 2017 OWASP Top Ten list but moves up to #7 on the 2021 list. This was a very highly scored risk on the Top 10 community survey but it also had enough data to make the Top 10 even without the survey score. Vulnerable Components are a known issue that we struggle to test, but they can cause a wide variety of problems for applications.
A7. Identification and Authentication Failures - Previously known as Broken Authentication, this category slid down from the second position in the 2017 list. Confirmation of the user's identity, authentication, and session management is critical to protect against authentication-related attacks.
A8. Software and Data Integrity Failures - A new category for 2021, this risk focuses on making assumptions related to software updates, critical data, and CI/CD pipelines without verifying integrity. Software and data integrity failures relate to code and infrastructure that does not protect against integrity violations. An example of this is where an application relies upon plugins, libraries, or modules from untrusted sources, repositories, and content delivery networks (CDNs). An insecure CI/CD pipeline can introduce the potential for unauthorized access, malicious code, or system compromise. Lastly, many applications now include auto-update functionality, where updates are downloaded without sufficient integrity verification and applied to the previously trusted application. Attackers could potentially upload their own updates to be distributed and run on all installations. Another example is where objects or data are encoded or serialized into a structure that an attacker can see and modify is vulnerable to insecure deserialization.
A9. Security Logging and Monitoring Failures - Returning to the OWASP Top 10 (and up to #9 from #10 in the 2017 list), this category is to help detect, escalate, and respond to active breaches. Without logging and monitoring, breaches cannot be detected. Many organizations don't log application activities properly, and even when they do, they don't monitor those logs to see what happened (or what is currently happening).
A10. Server Side Request Forgery (SSRF) - SSRF flaws occur whenever a web application is fetching a remote resource without validating the user-supplied URL. It allows an attacker to coerce the application to send a crafted request to an unexpected destination, even when protected by a firewall, VPN, or another type of network access control list (ACL). As modern web applications provide end-users with convenient features, fetching a URL becomes a common scenario. As a result, the incidence of SSRF is increasing. Also, the severity of SSRF is becoming higher due to cloud services and the complexity of architectures.
Published Jan 31, 2022
