1024 Words: Why Devops is Hard
#devops #cloud #virtualization Just because you don't detail the complexity doesn't mean it isn't there
It should be noted that this is one – just one – Java EE application and even it is greatly simplified (architectural flowcharts coming from the dev side of the house are extraordinarily complicated, owing to the number of interconnects and integrations required). Most enterprises have multiple applications that require just as many interconnects, with large enterprises numbering their applications in the hundreds.
Related blogs & articles:
Published Sep 04, 2012
