Technical Articles
F5 SMEs share good practice.
Lori_MacVittie
F5 Employee
F5 Employee
#webperf We often lay the blame for application performance woes on the nebulous (and apparently sentient-with-malevolent-tendencies) "network". But the truth is that the causes of application performance woes are more often than not related to the "first*" and "last" mile of connectivity. That's why optimization is as important, often more so, than acceleration. And yes, there is a difference.
* That whole "first mile" thing isn't the network as we generally see it, per se, but the network internal to the server. It's complicated, engineering things. Trust me, there's a bus over which data has to travel that slows things down. Besides, the analogy doesn't work well if there isn't a "first" mile to match the "last" mile so just run with it, okay?
Comments
The_Bhattman
The blame game, at least for the companies I have been in, are fundamentally about ego and/or laziness which doesn't solve the problem.
The approach I like to take is determine where most of the problem exists for the entire year. Ideally the helpdesk system would track the problem and solution as server, application, network, etc. This would provide where the % failures would exist. A company could use that to advance their troubleshooting in areas of where the highest probability of failures would exist.
My 2 cents,
-=Bhattman=-
Version history
Last update:
‎11-Nov-2013 03:51
Updated by:
Contributors
