Problem this snippet solves:
This sample applications allows for modification of a Virtual Servers default pool
Code :
#!/usr/bin/perl
# The contents of this file are subject to the "END USER LICENSE AGREEMENT FOR F5
# Software Development Kit for iControl"; you may not use this file except in
# compliance with the License. The License is included in the iControl
# Software Development Kit.
# Software distributed under the License is distributed on an "AS IS"
# basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
# the License for the specific language governing rights and limitations
# under the License.
# The Original Code is iControl Code and related documentation
# distributed by F5.
# The Initial Developer of the Original Code is F5 Networks,
# Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2004 F5 Networks,
# Inc. All Rights Reserved.  iControl (TM) is a registered trademark of F5 Networks, Inc.
# Alternatively, the contents of this file may be used under the terms
# of the GNU General Public License (the "GPL"), in which case the
# provisions of GPL are applicable instead of those above.  If you wish
# to allow use of your version of this file only under the terms of the
# GPL and not to allow others to use your version of this file under the
# License, indicate your decision by deleting the provisions above and
# replace them with the notice and other provisions required by the GPL.
# If you do not delete the provisions above, a recipient may use your
# version of this file under either the License or the GPL.
#use SOAP::Lite + trace => qw(method debug);
use SOAP::Lite;
use MIME::Base64;
# Validate Arguments
my $sHost = $ARGV[0];
my $sPort = $ARGV[1];
my $sUID = $ARGV[2];
my $sPWD = $ARGV[3];
my $sVirtual = $ARGV[4];
my $sPool = $ARGV[5];
my $sProtocol = "https";
if ( ("80" eq $sPort) or ("8080" eq $sPort) )
$sProtocol = "http";
if ( ($sHost eq "") or ($sPort eq "") or ($sUID eq "") or ($sPWD eq "") )
die ("Usage: SetVirtualDefaultPool.pl host port uid pwd virtual_name pool_name\n");
# Transport Information
sub SOAP::Transport::HTTP::Client::get_basic_credentials-->
return "$sUID" => "$sPWD";
$VirtualServer = SOAP::Lite
-> uri('urn
-> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi");
eval { $VirtualServer->transport->http_request->header
'Authorization' =>
'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')-->
$Pool = SOAP::Lite
-> uri('urn
eval { $Pool->transport->http_request->header
'Authorization' =>
if ( $sVirtual eq "" )
&getVirtualList();
elsif ( $sPool eq "" )
&getDefaultPool($sVirtual);
&getPoolList();
else
setDefaultPool($sVirtual, $sPool)
# sub getVirtualList()
$soapResponse = $VirtualServer->get_list();
&checkResponse($soapResponse);
@vs_list = @{$soapResponse->result};
print "Available Virtual Servers:\n";
foreach $vs (@vs_list)
print "  $vs\n";
# sub getPoolList()
sub getPoolList()
$soapResponse = $Pool->get_list();
@pool_list = @{$soapResponse->result};
print "Available Pools:\n";
foreach $pool (@pool_list)
print "  $pool\n";
# sub getDefaultPool()
my ($virtual_name) = (@_);
$soapResponse = $VirtualServer->get_default_pool_name
SOAP::Data->name(virtual_servers => [$virtual_name])
$def_pool = @pool_list[0];
print "Virtual Server '$virtual_name' default pool: $def_pool\n";
# sub setDefaultPool()
my ($virtual_name, $pool_name) = (@_);
$soapResponse = $VirtualServer->set_default_pool_name
SOAP::Data->name(virtual_servers => [$virtual_name]),
SOAP::Data->name(default_pools => [$pool_name])
print "Virtual Server '$virtual_name' default pool changed to '$pool_name'\n";
# checkResponse
sub checkResponse()
my ($soapResponse) = (@_);
if ( $soapResponse->fault )
print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
exit();
Comments
adavidjan_27668
Hey gus, could please help me of how to set the default pool using a simple curl rest call? I tried to use this script but I'm facing SSL certificate verfication problems.
Version history
Last update:
‎09-Mar-2015 13:57
Updated by:
Contributors
