The_Bhattman
Altostratus
Altostratus
Problem this snippet solves:
The following is an iRule that allows the F5 to serve a proxy pac file to a client without the need of hosting it on a web server or the proxy itself.
Simply create the iRule and associate it to a virtual address running a specific port that has no pools.
Definition
What the heck is a pacfile? Well it's a javascript file that defines how web browsers and other user agents can automatically choose the appropriate proxy server (access method) for fetching a given URL. So you might have specific sites that go through a proxy and some sites that do not. The pac file can do this for you.
To read up more about it you can go to the following links: http://en.wikipedia.org/wiki/Proxy_auto-config http://www.craigjconsulting.com/proxypac.html
Now back to the configuration...
How to use this snippet:
Example
VIP: 192.168.1.20: 80 TCP
Domain: Proxypacfile.intranet.com --> 192.168.1.20
Just set your browser up to use the automatic configuration script:
http://proxypacfile.intranet.com/proxy.pac
You can also set to other ports
Example:
VIP: 192.168.1.21: 9090 TCP
Domain: Proxypacfile2.intranet.com --> 192.168.1.21
http://proxypacfile2.intranet.com:9090/proxy.pac
Code :
when RULE_INIT {
   set pacfile {
     function FindProxyForURL(url, host) {
         if (isPlainHostName(host))
         return "DIRECT";
         if (shExpMatch(url, "http://10.*")||
         shExpMatch(url, "https://10.*")||
         shExpMatch(url, "ftp://10.*")||
         shExpMatch(url, "http://localhost*")||
         shExpMatch(url, "https://localhost*")||
         shExpMatch(url, "http://127.0.0.1*")||
         shExpMatch(url, "https://127.0.0.1*")||
         shExpMatch(url, "http://172.*")||
         shExpMatch(url, "https://172.*")||
         shExpMatch(url, "ftp://172.*"))
         return "DIRECT";
      if (dnsDomainIs(host, ".extranet.com")||
         dnsDomainIs(host, ".extranet2.com"))
         return "Proxy yourproxy.domain.com:8080";
         if (dnsDomainIs(host, ".intrant.com")||
         dnsDomainIs(host, ".intranet2.com"))
         return "DIRECT";
      return "PROXY yourproxy.domain.com:8080";
  switch -glob [string tolower [HTTP::uri]] {
   "/proxy.pac" {
      HTTP::respond 200 content $::pacfile "Content-Type" "application/x-ns-proxy-autoconfig" "pragma" "no-cache"
Version history
Last update:
‎18-Mar-2015 14:13
Updated by:
Contributors
