Perl Script to check GTM Wideip and its associated Pool status
Problem this snippet solves:
This Perl script will query the status and state of Wideip and its Associated Pool and pool member state
How to use this snippet:
gtmstate.pl < gtmsyncmember> < user> < pass> < wideip>
Code :
#!/usr/bin/perl
use SOAP::Lite;
use Data::Dumper;
my $BIGIP = $ARGV[0];
my $User = $ARGV[1];
my $Pass = $ARGV[2];
my $sWideIP = $ARGV[3];
sub SOAP::Transport::HTTP::Client::get_basic_credentials
  return "$User" => "$Pass";
&getWideIPPoolList($sWideIP);
sub SOAP::Deserializer::typecast
  my ($self, $value, $name, $attrs, $children, $type) = @_;
  my $retval = undef;
  if ( "{urn:iControl}GlobalLB.LBMethod" == $type )
    $retval = $value;
  return $retval;
sub GetInterface()
  my ($module, $name) = @_;
  $interface = SOAP::Lite
    -> uri("urn:iControl:$module/$name")
    -> readable(1)
    -> proxy("https://$BIGIP/iControl/iControlPortal.cgi");
  eval { $interface->transport->http_request->header
  ( 'Authorization' => 'Basic ' . MIME::Base64::encode("$User:$Pass", '') ); };
  return $interface;
sub getWideIPPoolList()
  my ($wideIP) = @_;
  print "WIDEIP: $wideIP\n";
  $GTMWideip = &GetInterface("GlobalLB", "WideIP");
  $soapResponse = $GTMWideip->get_wideip_pool(SOAP::Data->name(wide_ips => [$wideIP]));
  $soapResponse2 = $GTMWideip->get_enabled_state(SOAP::Data->name(wide_ips => [$wideIP]));
  $soapResponse3 = $GTMWideip->get_object_status(SOAP::Data->name(wide_ips => [$wideIP]));
  @WideIPPoolAofA = @{$soapResponse->result};
  @WideIPPoolA = @{@WideIPPoolAofA[0]};
  @states =@{$soapResponse2->result};
  @avail=@{$soapResponse3->result};
  print "Wideip State::@states\n";
  foreach $availa (@avail)
   $availb=$availa->{"availability_status"};
   print "Wideip Status:$availb\n";
  foreach $WideIPPool (@WideIPPoolA)
    $pool_name = $WideIPPool->{"pool_name"};
    print "  Pool $pool_name\n";
    &getWideIPPoolMemberList($pool_name);
sub getWideIPPoolMemberList()
  my ($pool) = @_;
  $GTMPool = &GetInterface("GlobalLB", "Pool");
  $GTMPoolmember=&GetInterface("GlobalLB","PoolMember");
  $soapResponse = $GTMPool->get_member(SOAP::Data->name(pool_names => [$pool]) );
  $soapResponse2=$GTMPool->get_enabled_state(SOAP::Data->name(pool_names => [$pool]));
  $soapResponse3=$GTMPool->get_object_status(SOAP::Data->name(pool_names => [$pool]));
  @states = @{$soapResponse2->result};
  @poolstate = @{$soapResponse3->result};
  foreach $poolavail (@poolstate)
   $pools=$poolavail->{"availability_status"};
   print "Pool Status:$pools\n";
  @PoolMemberDefinitionAofA = @{$soapResponse->result};
  @PoolMemberDefinitionA = @{@PoolMemberDefinitionAofA[0]};
  foreach $PoolMemberDefinition(@PoolMemberDefinitionA)
    $member = $PoolMemberDefinition->{"member"};
    $address = $member->{"address"};
    $port = $member->{"port"};
    print "  MEMBER: ${address}:${port}:STATE:@states\n";
Updated Jun 06, 2023
Version 2.0
Was this article helpful?
