Problem this snippet solves:
This example will query the Monitor Instances associated with the members of a given pool name. It will then group the results by member.
Code :
#!/usr/bin/perl
# The contents of this file are subject to the "END USER LICENSE AGREEMENT
# FOR F5 Software Development Kit for iControl"; you may not use this file
# except in compliance with the License. The License is included in the
# iControl Software Development Kit.
# Software distributed under the License is distributed on an "AS IS"
# basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
# the License for the specific language governing rights and limitations
# under the License.
# The Original Code is iControl Code and related documentation
# distributed by F5.
# The Initial Developer of the Original Code is F5 Networks,
# Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2005
# F5 Networks, Inc. All Rights Reserved.  iControl (TM) is a registered
# trademark of F5 Networks, Inc.
# Alternatively, the contents of this file may be used under the terms
# of the GNU General Public License (the "GPL"), in which case the
# provisions of GPL are applicable instead of those above.  If you wish
# to allow use of your version of this file only under the terms of the
# GPL and not to allow others to use your version of this file under the
# License, indicate your decision by deleting the provisions above and
# replace them with the notice and other provisions required by the GPL.
# If you do not delete the provisions above, a recipient may use your
# version of this file under either the License or the GPL.
#use SOAP::Lite + trace => qw(method debug);
use SOAP::Lite;
use MIME::Base64;
BEGIN {push (@INC, "..");}
use iControlTypeCast;
# Validate Arguments
my $sHost = $ARGV[0];
my $sPort = $ARGV[1];
my $sUID = $ARGV[2];
my $sPWD = $ARGV[3];
my $sPool = $ARGV[4];
my $sProtocol = "https";
if ( ("80" eq $sPort) or ("8080" eq $sPort) )
$sProtocol = "http";
if ( ($sHost eq "") or ($sPort eq "") or ($sUID eq "") or ($sPWD eq "") )
die ("Usage: PoolMemberMonitors.pl host port uid pwd [pool_name]\n");
# Transport Information
sub SOAP::Transport::HTTP::Client::get_basic_credentials-->
return "$sUID" => "$sPWD";
$Pool = SOAP::Lite
-> uri('urn
-> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi");
$Pool->transport->http_request->header
'Authorization' =>
'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')-->
if ( $sPool eq "" )
&getAllPoolMemberMonitorInfo();
else
&getPoolMemberMonitorInfo($sPool);
# checkResponse
sub checkResponse()
my ($soapResponse) = (@_);
if ( $soapResponse->fault )
print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
exit();
# getAllPoolMemberMonitorInfo
sub getAllPoolMemberMonitorInfo()
$soapResponse = $Pool->get_list();
&checkResponse($soapResponse);
my @pool_list = @{$soapResponse->result};
&getPoolMemberMonitorInfo(@pool_list);
# getAddress()
sub getAddress()
($MonitorInstance) = (@_);
$instance = $MonitorInstance->{"instance"};
$template_name = $instance->{"template_name"};
$instance_definition = $instance->{"instance_definition"};
$ipport = $instance_definition->{"ipport"};
$address = $ipport->{"address"};
$port = $ipport->{"port"};
return "$address:$port";
# sort_by_member
sub sort_by_member {
return &getAddress($a) cmp &getAddress($b);
# getPoolMemberMonitorInfo
sub getPoolMemberMonitorInfo()
my @pool_list = @_;
my $last_member = "";
# Get Member List
$soapResponse = $Pool->get_monitor_instance
SOAP::Data->name(pool_names => [@pool_list])
my @MonitorInstanceStateAofA = @{$soapResponse->result};
for $i (0 .. $#MonitorInstanceStateAofA)
print "Pool $pool_list[$i] {\n";
$MonitorInstanceStateList = $MonitorInstanceStateAofA[$i];
foreach $MonitorInstance
sort sort_by_member @{$MonitorInstanceStateList}
$address_type = $instance_definition->{"address_type"};
$instance_state = $MonitorInstance->{"instance_state"};
$enabled_state = $MonitorInstance->{"enabled_state"};
$current_member = "$address:$port";
if ( $current_member ne $last_member )
# New member so print header
$last_member = $current_member;
print "  Member   : $current_member\n";
print "    Template : $template_name\n";
print "               Address Type  : $address_type\n";
print "               Instance State: $instance_state\n";
print "               Enabled State :";
if ( 0 == $enabled_state )
print "Disabled";
else
print "Enabled";
print "\n";
print "}\n";
Version history
Last update:
‎09-Mar-2015 11:27
Updated by:
Contributors
