Perl GTM Pool
Problem this snippet solves:
Here's a little sample perl script that illustrates how to get and set the enabled state of a GTM Pool.
Code :
#!/usr/bin/perl #---------------------------------------------------------------------------- # The contents of this file are subject to the "END USER LICENSE AGREEMENT FOR F5 # Software Development Kit for iControl"; you may not use this file except in # compliance with the License. The License is included in the iControl # Software Development Kit. # # Software distributed under the License is distributed on an "AS IS" # basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See # the License for the specific language governing rights and limitations # under the License. # # The Original Code is iControl Code and related documentation # distributed by F5. # # The Initial Developer of the Original Code is F5 Networks, # Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2004 F5 Networks, # Inc. All Rights Reserved. iControl (TM) is a registered trademark of F5 Networks, Inc. # # Alternatively, the contents of this file may be used under the terms # of the GNU General Public License (the "GPL"), in which case the # provisions of GPL are applicable instead of those above. If you wish # to allow use of your version of this file only under the terms of the # GPL and not to allow others to use your version of this file under the # License, indicate your decision by deleting the provisions above and # replace them with the notice and other provisions required by the GPL. # If you do not delete the provisions above, a recipient may use your # version of this file under either the License or the GPL. #---------------------------------------------------------------------------- #use SOAP::Lite + trace => qw(method debug); use SOAP::Lite; use MIME::Base64; use Math::BigInt; BEGIN { push (@INC, ".."); } use iControlTypeCast; #---------------------------------------------------------------------------- # Validate Arguments #---------------------------------------------------------------------------- my $sHost = $ARGV[0]; my $sPort = $ARGV[1]; my $sUID = $ARGV[2]; my $sPWD = $ARGV[3]; my $sPool = $ARGV[4]; my $sEnable = $ARGV[5]; my $sProtocol = "https"; if ( ("80" eq $sPort) or ("8080" eq $sPort) ) { $sProtocol = "http"; } if ( ($sHost eq "") or ($sPort eq "") or ($sUID eq "") or ($sPWD eq "") ) { &usage(); } sub usage() { my ($sCmd) = @_; print "Usage: GlobalLBPool.pl host port uid pwd pool [enable|disable]\n"; exit(); } #---------------------------------------------------------------------------- # Transport Information #---------------------------------------------------------------------------- sub SOAP::Transport::HTTP::Client::get_basic_credentials--> { return "$sUID" => "$sPWD"; } $Pool = SOAP::Lite -> uri('urn -> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi"); eval { $Pool->transport->http_request->header ( 'Authorization' => 'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')--> ); }; if ( $sPool eq "" ) { &GetPoolList(); } else { if ( $sEnable eq "" ) { &GetPoolState($sPool); } else { &SetPoolState($sPool, $sEnable); } } sub GetPoolList() { $soapResponse = $Pool->get_list(); &checkResponse($soapResponse); @pools = @{$soapResponse->result}; foreach $pool (@pools) { print "$pool\n"; } } #---------------------------------------------------------------------------- # GetPoolState #---------------------------------------------------------------------------- sub GetPoolState() { my ($pool) = (@_); $soapResponse = $Pool->get_enabled_state( SOAP::Data->name(pool_names => [$pool]) ); &checkResponse($soapResponse); @states = @{$soapResponse->result}; foreach $state (@states) { print "$state\n"; } } sub SetPoolState() { my($pool, $state) = (@_); print " Setting pool '$pool' to state '$state'\n"; if ( $state eq "enabled" ) { $state = "STATE_ENABLED"; } else { $state = "STATE_DISABLED"; } my @gtmPools; push @gtmPools, $pool; # push @gtmPools, "gtm_pool_2"; my @gtmEnabled; push @gtmEnabled, $state; # push @gtmEnabled, $state; $soapResponse = $Pool->set_enabled_state( SOAP::Data->name(pool_names => [@gtmPools]), SOAP::Data->name(states => [@gtmEnabled]) ); &checkResponse($soapResponse); &GetPoolState($pool); } #---------------------------------------------------------------------------- # checkResponse #---------------------------------------------------------------------------- sub checkResponse() { my ($soapResponse) = (@_); if ( $soapResponse->fault ) { print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n"; exit(); } }
Published Mar 08, 2015
