Perl Establish Device Trust, Create Sync-Failover device-group, and add members
Problem this snippet solves:
This Perl reference application will establish a traditional HA pair on V11 software. It establishes device trust, creates a sync-failover device-group, and then populates the members of the pair in that group.
Be advised: This application has certain hard-coded options that you will need to either create a command line argument for or modify before attempting to use it. That is why I refer to it as a reference application. It is written to be run on the second member of a pair.
Code :
# The contents of this file are subject to the "END USER LICENSE AGREEMENT FOR F5 # Software Development Kit for iControl"; you may not use this file except in # compliance with the License. The License is included in the iControl # Software Development Kit. # # Software distributed under the License is distributed on an "AS IS" # basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See # the License for the specific language governing rights and limitations # under the License. # # The Original Code is iControl Code and related documentation # distributed by F5. # # The Initial Developer of the Original Code is F5 Networks, # Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2004 F5 Networks, # Inc. All Rights Reserved. iControl (TM) is a registered trademark of F5 Networks, Inc. # # Alternatively, the contents of this file may be used under the terms # of the GNU General Public License (the "GPL"), in which case the # provisions of GPL are applicable instead of those above. If you wish # to allow use of your version of this file only under the terms of the # GPL and not to allow others to use your version of this file under the # License, indicate your decision by deleting the provisions above and # replace them with the notice and other provisions required by the GPL. # If you do not delete the provisions above, a recipient may use your # version of this file under either the License or the GPL. #---------------------------------------------------------------------------- #use SOAP::Lite + trace => qw(method debug); $ENV{PERL_LWP_SSL_VERIFY_HOSTNAME}=0; use SOAP::Lite; use MIME::Base64; use iControlTypeCast; my $sHost = $ARGV[0]; my $sUID = admin; my $sPWD = $ARGV[1]; my $b1n = $ARGV[2]; my $b2n = $ARGV[3]; my $cadaddr = 10.255.255.1; $dtrmgmt = SOAP::Lite -> uri('urn:iControl:Management/Trust') -> readable(1) -> proxy("https://$sHost/iControl/iControlPortal.cgi"); eval { $dtrmgmt->transport->http_request->header( 'Authorization' => 'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')); }; $dgmgmt = SOAP::Lite -> uri('urn:iControl:Management/DeviceGroup') -> readable(1) -> proxy("https://$sHost/iControl/iControlPortal.cgi"); eval { $dgmgmt->transport->http_request->header( 'Authorization' => 'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')); }; #---------------------------------------------------------------------------- # checkResponse makes sure the error isn't a SOAP error #---------------------------------------------------------------------------- sub checkResponse() { my ($soapResponse) = (@_); if ( $soapResponse->fault ) { print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n"; exit(); } } sub buildtrust { $soapResponse = $dtrmgmt->add_authority_device ( SOAP::Data->name (address => "$cadaddr"), SOAP::Data->name ( username => "$sUID" ), SOAP::Data->name ( password => "$sPWD" ), SOAP::Data->name ( device_object_name => "$b1n" ), SOAP::Data->name ( browser_cert_serial_number => "" ), SOAP::Data->name ( browser_cert_signature => "" ), SOAP::Data->name ( browser_cert_sha1_fingerprint => "" ), SOAP::Data->name ( browser_cert_md5_fingerprint => "" ), ); &checkResponse($soapResponse); } sub builddg { $soapResponse = $dgmgmt->create ( SOAP::Data->name (device_groups => ["ex-dv-grp"] ), SOAP::Data->name ( types => [DGT_FAILOVER] ), ); &checkResponse($soapResponse); } sub adddevices { $soapResponse = $dgmgmt->add_device ( SOAP::Data->name (device_groups => ["ex-dv-grp"] ), SOAP::Data->name ( devices => [["$b1n","$b2n"]] ) ); &checkResponse($soapResponse); } #Main Program Logic &buildtrust; &builddg; &adddevices;
Published Mar 08, 2015
