Perl Create Pool
Problem this snippet solves:
This perl sample will illustrate how to query a list of pools and pool members or create a new pool with a specified list of members.
Code :
#use SOAP::Lite + trace => qw(method debug); use SOAP::Lite; #---------------------------------------------------------------------------- # Validate Arguments #---------------------------------------------------------------------------- my $sHost = $ARGV[0]; my $sUID = $ARGV[1]; my $sPWD = $ARGV[2]; my $sPool = $ARGV[3]; my $sMemberList = $ARGV[4]; sub usage() { die ("Usage: PoolMember.pl host port uid pwd [poolname member1:ip,member2:ip,...])\n"); } if ( ($sHost eq "") or ($sUID eq "") or ($sPWD eq "") ) { usage(); } #---------------------------------------------------------------------------- # Transport Information #---------------------------------------------------------------------------- sub SOAP::Transport::HTTP::Client::get_basic_credentials { return "$sUID" => "$sPWD"; } $Pool = SOAP::Lite -> uri('urn:iControl:LocalLB/Pool') -> readable(1) -> proxy("https://$sHost/iControl/iControlPortal.cgi"); #---------------------------------------------------------------------------- # Attempt to add auth headers to avoid dual-round trip #---------------------------------------------------------------------------- eval { $Pool->transport->http_request->header ( 'Authorization' => 'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '') ); }; #---------------------------------------------------------------------------- # Main logic #---------------------------------------------------------------------------- if ( "" eq $sPool ) { #------------------------------------------------------------------------ # No pool supplied. Query pool list and display members for given pool #------------------------------------------------------------------------ $soapResponse = $Pool->get_list(); &checkResponse($soapResponse); @pool_list = @{$soapResponse->result}; $soapResponse = $Pool->get_member ( SOAP::Data->name(pool_names => [@pool_list]) ); @memberListAofA = @{$soapResponse->result}; for $i (0 .. $#pool_list) { $pool = @pool_list[$i]; @memberListA = @{@memberListAofA[$i]}; print "POOL $pool\n"; foreach $member (@memberListA) { $addr = $member->{"address"}; $port = $member->{"port"}; print " -> $addr:$port\n"; } } } elsif ( "" ne $sMemberList ) { #------------------------------------------------------------------------ # Pool and member list supplied, try to create new pool #------------------------------------------------------------------------ @MemberDefA; @memberListA = split(/,/, $sMemberList, 5); foreach $memberItem (@memberListA) { ($memberAddr, $memberPort) = split(/:/, $memberItem, 2); $member = { address => $memberAddr, port => $memberPort }; push @memberDefA, $member; } push @memberDefAofA, [@memberDefA]; $soapResponse = $Pool->create( SOAP::Data->name(pool_names => [$sPool]), SOAP::Data->name(lb_methods => ["LB_METHOD_ROUND_ROBIN"]), SOAP::Data->name(members => [@memberDefAofA]) ); &checkResponse($soapResponse); print "Pool $sPool created successfully\n"; } else { #------------------------------------------------------------------------ # Pool supplied, but no member list so error out. #------------------------------------------------------------------------ &usage; } #---------------------------------------------------------------------------- # checkResponse makes sure the error isn't a SOAP error #---------------------------------------------------------------------------- sub checkResponse() { my ($soapResponse) = (@_); if ( $soapResponse->fault ) { print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n"; exit(); } }
Published Mar 08, 2015
