Perl Certificate Info
Problem this snippet solves:
This perl application will display the information about the certificates on the BIG-IP system.
Code :
#!/usr/bin/perl #---------------------------------------------------------------------------- # The contents of this file are subject to the "END USER LICENSE AGREEMENT FOR F5 # Software Development Kit for iControl"; you may not use this file except in # compliance with the License. The License is included in the iControl # Software Development Kit. # # Software distributed under the License is distributed on an "AS IS" # basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See # the License for the specific language governing rights and limitations # under the License. # # The Original Code is iControl Code and related documentation # distributed by F5. # # The Initial Developer of the Original Code is F5 Networks, # Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2004 F5 Networks, # Inc. All Rights Reserved. iControl (TM) is a registered trademark of F5 Networks, Inc. # # Alternatively, the contents of this file may be used under the terms # of the GNU General Public License (the "GPL"), in which case the # provisions of GPL are applicable instead of those above. If you wish # to allow use of your version of this file only under the terms of the # GPL and not to allow others to use your version of this file under the # License, indicate your decision by deleting the provisions above and # replace them with the notice and other provisions required by the GPL. # If you do not delete the provisions above, a recipient may use your # version of this file under either the License or the GPL. #---------------------------------------------------------------------------- #use SOAP::Lite + trace => qw(method debug); use SOAP::Lite; use MIME::Base64; use Math::BigInt; BEGIN { push (@INC, ".."); } use iControlTypeCast; #---------------------------------------------------------------------------- # Validate Arguments #---------------------------------------------------------------------------- my $sHost = $ARGV[0]; my $sPort = $ARGV[1]; my $sUID = $ARGV[2]; my $sPWD = $ARGV[3]; my $sMode = $ARGV[4]; my $sProtocol = "https"; if ( ("80" eq $sPort) or ("8080" eq $sPort) ) { $sProtocol = "http"; } if ( ($sHost eq "") or ($sPort eq "") or ($sUID eq "") or ($sPWD eq "") ) { &usage(); } sub usage() { my ($sCmd) = @_; print "Usage: CertInfo.pl host port uid pwd [ManagementModeType]\n"; print " ManagementModeType\n"; print " ------------------\n"; print " MANAGEMENT_MODE_DEFAULT - keys/certs used in SSL profiles\n"; print " MANAGEMENT_MODE_WEBSERVER - keys/certs used by the admin web server\n"; print " MANAGEMENT_MODE_EM - keys/certs used by Enterprise Manager\n"; print " MANAGEMENT_MODE_IQUERY - keys/certs used by GTM's iQuery GTM directory\n"; print " MANAGEMENT_MODE_IQUERY_BIG3D - keys/certs used by GTM's iQuery big3d directory\n"; exit(); } #---------------------------------------------------------------------------- # Transport Information #---------------------------------------------------------------------------- sub SOAP::Transport::HTTP::Client::get_basic_credentials { return "$sUID" => "$sPWD"; } $KeyCertificate = SOAP::Lite -> uri('urn:iControl:Management/KeyCertificate') -> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi"); eval { $KeyCertificate->transport->http_request->header ( 'Authorization' => 'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '') ); }; if ( $sMode eq "" ) { $sMode = "MANAGEMENT_MODE_DEFAULT"; } &GetCertInfo($sMode); sub GetCertInfo() { my ($mode) = (@_); $soapResponse = $KeyCertificate->get_certificate_list( SOAP::Data->name(mode => $mode) ); &checkResponse($soapResponse); @CertificateInformationA = @{$soapResponse->result}; foreach $CertificateInformation (@CertificateInformationA) { $is_bundled = $CertificateInformation->{"is_bundled"}; $file_name = $CertificateInformation->{"file_name"}; print "Certificate Info\n"; print " Is Bundled : $is_bundled\n"; print " File Name : $file_name\n"; $certificate = $CertificateInformation->{"certificate"}; $cert_info = $certificate->{"cert_info"}; $id = $cert_info->{"id"}; $email = $cert_info->{"email"}; print " Cert Info\n"; print " Id : $id\n"; print " Email : $email\n"; $cert_type = $certificate->{"cert_type"}; $key_type = $certificate->{"key_type"}; $bit_length = $certificate->{"bit_length"}; $version = $certificate->{"version"}; $serial_number = $certificate->{"serial_number"}; $expiration_string = $certificate->{"expiration_string"}; $expiration_date = $certificate->{"expiration_date"}; print " Cert Type : $cert_type\n"; print " Key Type : $key_type\n"; print " Bit Length : $bit_length\n"; print " Version : $version\n"; print " Serial # : $serial_number\n"; print " Expiration : $expiration_string ($expiration_date)\n"; $subject = $certificate->{"subject"}; $s_common_name = $subject->{"common_name"}; $s_country_name = $subject->{"country_name"}; $s_state_name = $subject->{"state_name"}; $s_locality_name = $subject->{"locality_name"}; $s_organization_name = $subject->{"organization_name"}; $s_division_name = $subject->{"division_name"}; print " Subject\n"; print " Common Name : $s_common_name\n"; print " Country : $s_country_name\n"; print " State : $s_state_name\n"; print " Locality : $s_locality_name\n"; print " Organization : $s_organization_name\n"; print " Division : $s_division_name\n"; $issuer = $certificate->{"issuer"}; $i_common_name = $issuer->{"common_name"}; $i_country_name = $issuer->{"country_name"}; $i_state_name = $issuer->{"state_name"}; $i_locality_name = $issuer->{"locality_name"}; $i_organization_name = $issuer->{"organization_name"}; $i_division_name = $issuer->{"division_name"}; print " Issuer\n"; print " Common Name : $i_common_name\n"; print " Country : $i_country_name\n"; print " State : $i_state_name\n"; print " Locality : $i_locality_name\n"; print " Organization : $i_organization_name\n"; print " Division : $i_division_name\n"; print "---------------------\n"; } } #---------------------------------------------------------------------------- # checkResponse #---------------------------------------------------------------------------- sub checkResponse() { my ($soapResponse) = (@_); if ( $soapResponse->fault ) { print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n"; exit(); } }
Published Mar 09, 2015
