NTLM Authenticated Proxy External Monitor
Problem this snippet solves:
How to use this snippet:
This monitor is used to monitor the availability of a web page through a NTLM authenticated proxy.
The default HTTP monitor relies on receiving a 401 Authenticate message to trigger the NTLM handshake, proxies respond with a 407 Proxy Authenticate message instead, which causes the monitor to fail.
Set the following variable: URI-The requested host/page to send the request to. (e.g. www.host.com/page1 or https://www.host.com/page.html) USER-Proxy Username PASS-Proxy Password RECV-Receive String to look for
Code :
#!/bin/sh # #Name:external_monitor_NTLM_Proxyauth #Author:Matt Elkington #Contact:melkington@integrity360.com #Date:23/01/2017 #Description:An external monitor to allow monitoring of a host through a NTLM Authenticated proxy #This is to work around the fact that the standard http monitor will only use NTLM if #it receives a 401 Authenticate message and ignores a 407 Proxy Authenticate message # #Change Log #VersionChangeDate #1.0Initial Monitor23/01/2017 # # #Port and IP address are supplied automatically a variables $1 and $2 byt the LTM: #$1 = IP (nnn.nnn.nnn.nnn notation) #$2 = port (decimal, host byte order) # #The following variables must be set in the monitor definitation: # #URI-The requested host/page to send the request to. (e.g. www.host.com/page1 or https://www.host.com/page.html) #USER-Proxy Username #PASS-Proxy Password #RECV-Receive String to look for # # remove IPv6/IPv4 compatibility prefix (LTM passes addresses in IPv6 format) NODE=`echo ${1} | sed 's/::ffff://'` PORT=${2} PIDFILE="/var/run/`basename ${0}`.${NODE}_${PORT}.pid" # kill of the last instance of this monitor if hung and log current pid if [ -f $PIDFILE ] then echo "EAV exceeded runtime needed to kill ${IP}:${PORT}" | logger -p local0.error kill -9 `cat $PIDFILE` > /dev/null 2>&1 fi echo "$$" > $PIDFILE # send request & check for expected response curl ${URI} --proxy ${NODE}:${PORT} -U ${USER}:${PASS} --proxy-ntlm -k | grep -i "${RECV}" 2>&1 > /dev/null # mark node UP if expected response was received if [ $? -eq 0 ] then # Remove the PID file rm -f $PIDFILE echo "UP" else # Remove the PID file rm -f $PIDFILE fi exit
Tested this on version:
11.6Published Jan 23, 2017
