cwkim_261931
Problem this snippet solves:
Hello~
I created iCall and generate event for working iCall's script. But.... It is not working.
list sys icall script change_iRule2 sys icall script change_iRule2 {
app-service none
definition {
    tmsh::modify ltm virtual v_198.100__443 rules { vip_snatpool }
    tmsh::modify ltm virtual v_198.101__443 rules { vip_snatpool }
description none
events none
list sys icall handler triggered change_iRule2{
subscriptions {
    change_iRule2 {
        event-name change_iRule2
I gernerated event
  • generate sys icall event change_iRule2
And I checked bellow status......
  • Sys::iCall::Event Triggered Handler: change_iRule2
  • Events matching filters 11
  • Events causing handler to run 11
  • Creation time 01/24/17 16:38:35
  • Current status active
  • Time since last status change 01/24/17 16:38:35
But, Configuration(virtual server's iRule) is not change....
Plz help me. T..T
Code :
    app-service none
    definition {
    description none
    events none
create sys icall handler triggered change_iRule2 script change_iRule2 subscriptions add { change_iRule2 { event-name change_iRule2 } }
Version history
Last update:
‎24-Jan-2017 00:33
Updated by:
Contributors
