Problem this snippet solves:
when CLIENT_ACCEPTED {
# Save the name of the virtual server's default pool before it's change in this iRule set default_pool [LB::server pool] } when HTTP_REQUEST { switch -glob [HTTP::path] { "/abc/proxy.jsp" { pool $default_pool } "/xyz*" { pool xyz_pool } ... default { HTTP::redirect "https://www.google.com" } } }
Code :
        "/abc/proxy.jsp" {
            pool $default_pool
        "/xyz*" {
            pool  xyz_pool
        default {
Version history
Last update:
‎25-Aug-2016 12:21
Updated by:
Contributors
