Problem this snippet solves:
This code was written to solve this issue
REF - https://devcentral.f5.com/s/feed/0D51T00006i7jWpSAI
Specification:
  • 2 clusters with 2 nodes each one.
  • each cluster will be served as active-passive method.
  • each node in the cluster will be served as round robin.
  • when a cluster changes to active, it will keep this status although the initial active cluster change back to up status.
  • Only one BIG-IP device.
There are many topics suggesting to use "Manual Resume" trying to goal this specifications, but this requires to manually restore each node when is back online. My initial idea was to have an unattended virtual server.
To do so, I use a combination of persistence and an internal virtual server loadbalancing (Vip-targeting-Vip in the same device).
How to use this snippet:
This scenario is composed by the next set of objects:
  • 4 nodes (Node1, Node2, Node3, Node4)
  • 1 additional node called "internal_node" (which represents the VIP used on VIP-Targeting-VIP)
  • 2 pools called "ClusterA_pool" and "ClusterB_pool" (which points to each pair of nodes)
  • 1 additional pool called "MyPool" (which points the two internal VIP)
  • 2 virtual servers called "ClusterA_vs" and "ClusterB_vs" (which use RoundRobin to the pools of the same name)
  • 1 virtual server called "MyVS" (which is the visible VS and points to "MyPool")
By the way, I use a "Slow Ramp Time" of 0 to reduce the failover time.
Following you can find an example of configuration:
ltm virtual MyVS {
  destination 10.130.40.150:http
  ip-protocol tcp
  mask 255.255.255.255
  persist {
    universal {
      default yes
  pool MyPool
  profiles {
    tcp { }
  rules {
    MyRule
  source 0.0.0.0/0
  translate-address enabled
  translate-port enabled
  vs-index 53
ltm virtual ClusterA_vs {
  destination 10.130.40.150:1001
  ip-protocol tcp
  pool ClusterA_pool
  profiles {
    tcp { }
  source 0.0.0.0/0
  vs-index 54
ltm virtual ClusterB_vs {
  destination 10.130.40.150:1002
  ip-protocol tcp
  pool ClusterB_pool
  profiles {
    tcp { }
  source 0.0.0.0/0
  vs-index 55
ltm pool ClusterA_pool {
  members {
    Node1:http {
      address 10.130.40.201
      session monitor-enabled
      state up
    Node2:http {
      address 10.130.40.202
      state up
  monitor tcp
  slow-ramp-time 0
ltm pool ClusterB_pool {
  members {
    Node3:http {
      address 10.130.40.203
      state up
    Node4:http {
      address 10.130.40.204
      state up
  monitor tcp
  slow-ramp-time 0
ltm node local_node {
  address 10.130.40.150
Code :
when CLIENT_ACCEPTED {
    set initial 0
    set entry ""
when LB_SELECTED {
    incr initial
    # Checks if persistence entry exists
    catch { set entry [persist lookup uie [virtual name]] }
    # Loadbalancing selection base on persistence
    if { $entry eq "" } {
        set selection [LB::server port]
        set selection [lindex [split $entry " "] 2]
        set status [LB::status pool MyPool member [LB::server addr] $selection]
        if { $status ne "up" } {
            catch { [persist delete uie [virtual name]] }
    # Adds a new persistence entry
    catch { persist add uie [virtual name] }
    # Applies the selection
    switch $selection {
        # This numbers represents the ports used at the VIP-targeting-VIP
        "1001" {
            LB::reselect virtual ClusterA_vs
        "1002" {
            LB::reselect virtual ClusterB_vs
Tested this on version:
12.1
Version history
Last update:
‎14-Mar-2019 11:07
Updated by:
Contributors
