Joe_Jordan
F5 Employee
F5 Employee
Problem this snippet solves:
This F5 contributed, release candidate iApp template provides a (temporary) way of quickly enabling/disabling Web Acceleration on a per user session basis, using a browser cookie. This can be useful for debugging or benchmarking purposes.
The template creates a new virtual server using the same IP address as the existing virtual server for which you want to toggle acceleration, but on a different service port. This new virtual server can set and delete the accel-disable cookie when you browse to it.
This version of this iApp template is now found on downloads.f5.com in the iApp templates package. For more information, see the inline help and the Help tab in the template.
Code :
46229
Version history
Last update:
‎11-Mar-2015 13:31
Updated by:
Contributors
