Problem this snippet solves:
This script will set a pool members state to FORCED DOWN if it determines that a health monitor failed (MONITOR_STATUS_DOWN). The reasoning behind this is that it is sometimes necessary to perform maintenance on a node if a health monitor fails. This will disable future client connections until the maintenance can be performed.
Code :
#!/usr/bin/perl
# The contents of this file are subject to the "END USER LICENSE AGREEMENT
# FOR F5 Software Development Kit for iControl"; you may not use this file
# except in compliance with the License. The License is included in the
# iControl Software Development Kit.
# Software distributed under the License is distributed on an "AS IS"
# basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
# the License for the specific language governing rights and limitations
# under the License.
# The Original Code is iControl Code and related documentation
# distributed by F5.
# The Initial Developer of the Original Code is F5 Networks,
# Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2005
# F5 Networks, Inc. All Rights Reserved.  iControl (TM) is a registered
# trademark of F5 Networks, Inc.
# Alternatively, the contents of this file may be used under the terms
# of the GNU General Public License (the "GPL"), in which case the
# provisions of GPL are applicable instead of those above.  If you wish
# to allow use of your version of this file only under the terms of the
# GPL and not to allow others to use your version of this file under the
# License, indicate your decision by deleting the provisions above and
# replace them with the notice and other provisions required by the GPL.
# If you do not delete the provisions above, a recipient may use your
# version of this file under either the License or the GPL.
#use SOAP::Lite + trace => qw(method debug);
use SOAP::Lite;
use MIME::Base64;
#BEGIN {push (@INC, "..");}
#use iControlTypeCast;
# Validate Arguments
my $sHost = $ARGV[0];
my $sPort = $ARGV[1];
my $sUID = $ARGV[2];
my $sPWD = $ARGV[3];
my $sPool = $ARGV[4];
my $sPoolMember = $ARGV[5];
my $sProtocol = "https";
if ( ("80" eq $sPort) or ("8080" eq $sPort) )
$sProtocol = "http";
if ( ($sHost eq "") or ($sPort eq "") or ($sUID eq "") or ($sPWD eq "") )
die ("Usage: checkPoolMember.pl host port uid pwd pool_name memberip_port\n");
# Transport Information
sub SOAP::Transport::HTTP::Client::get_basic_credentials-->
return "$sUID" => "$sPWD";
sub SOAP::Deserializer::typecast-->
my ($self, $value, $name, $attrs, $children, $type) = @_;
my $retval = undef;
if ( $type eq "{urn:iControl}LocalLB.MonitorStatus" )
$retval = $value;
return $retval;
$Pool = SOAP::Lite
-> uri('urn
-> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi");
eval { $Pool->transport->http_request->header
'Authorization' => 'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')-->
$PoolMember = SOAP::Lite
-> uri('urn
eval { $PoolMember->transport->http_request->header
if ( ($sPool eq "") or ($sPoolMember eq "") )
usage();
&checkPoolMember($sPool, $sPoolMember);
# checkResponse
sub checkResponse()
my ($soapResponse) = (@_);
if ( $soapResponse->fault )
print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
exit();
# checkPoolMember
sub checkPoolMember()
($sPool, $sPoolMember) = (@_);
($sMemberAddr, $sMemberPort) = split(/:/, $sPoolMember, 2);
print "checking status of pool member $sPool/$sMemberAddr:$sMemberPort\n";
$soapResponse = $PoolMember->get_monitor_status
SOAP::Data->name(pool_names => [$sPool])
&checkResponse($soapResponse);
@MonitorStatusAofA = @{$soapResponse->result};
@MonitorStatusList = @{$MonitorStatusAofA[0]};
$bFoundMember = 0;
# Loop over monitor statuses until we found a match on the
# specified pool member
foreach $MonitorStatus (@MonitorStatusList)
$member = $MonitorStatus->{"member"};
$addr = $member->{"address"};
$port = $member->{"port"};
$monitor_status = $MonitorStatus->{"monitor_status"};
if ( ($sMemberAddr eq $addr) and ($sMemberPort eq $port) )
print "Monitor Status => $monitor_status\n";
$bFoundMember = 1;
if ( $monitor_status eq "MONITOR_STATUS_DOWN" )
# Monitor has been marked down, do disable it.
&disablePoolMember($sPool, $sMemberAddr, $sMemberPort);
if ( 0 == $bFoundMember )
print "Member $sPoolMember not found in pool $sPool\n";
# disablePoolMember()
sub disablePoolMember()
($sPool, $sMemberAddr, $sMemberPort) = (@_);
&setPoolMemberState($sPool, $sMemberAddr, $sMemberPort, "STATE_DISABLED");
# enablePoolMember()
sub enablePoolMember()
&setPoolMemberState($sPool, $sMemberAddr, $sMemberPort, "STATE_ENABLED");
# setPoolMemberState()
sub setPoolMemberState()
($sPool, $sMemberAddr, $sMemberPort, $sMonitorState) = (@_);
$member =
address => $sMemberAddr,
port => $sMemberPort
$monitor_state = $sMonitorState;
$MonitorState =
member => $member,
monitor_state => $monitor_state
@MonitorStateList =
[$MonitorState]
print "disabling pool member...\n";
$soapResponse = $PoolMember->set_monitor_state
SOAP::Data->name(pool_names => [$sPool]),
SOAP::Data->name(monitor_states => [@MonitorStateList])
print "Monitor status => MONITOR_STATUS_FORCED_DOWN\n";
Version history
Last update:
‎07-Mar-2015 15:15
Updated by:
Contributors
