delete_devices
Problem this snippet solves:
Introduced: EM_v3.0
Use the delete_devices API to remove devices currently being managed by an Enterprise Manager.
How to use this snippet:
Prototype
Python
ic.Management.EM.deletedevices(deviceaddresses)
C#, Java, and Perl
ic.getManagementEM().delete_devices(deviceAddresses);
Inputs
Name Type Description
IP addressesString SequenceThis parameter specifies the IP addresses or hostnames of the F5 device(s) that you want to delete from the list of managed devices.
Return values
There is no explicit return when this API executes successfully.
Exceptions
The table lists error categories that Enterprise Manager can raise if the API call fails.
Exception Name This exception is raised when...
AccessDeniedThe credentials supplied by the client do not satisfy the F5 device's validation requirements.
OperationFailedThe API call causes an operation error.
InvalidArgumentThe API call contains an invalid argument.
Code :
To view a code sample, click the relevant code type.
C# (.net)
Java
Perl
Python
Updated Jun 05, 2023
Version 2.0
