Create DNS monitor without external dig or nslookup
Problem this snippet solves:
NOTE: This was written in 10.x and early 11.x days. Since then, a native DNS monitor has been added to the product.
This example will create a udp monitor with proper send and receive strings to query a DNS server. Much of the heavy lifting was pulled from an iApp template that ships with v11. I have tested this out on as far back as 10.2.1 base.
Installation
One method to get this into your config would be:
In the code block below, click the icon in the top right corner '<>' view source. Ctrl-A, Ctrl-C to select and copy all.
Then in tmsh, type 'edit /cli script dns.monitor' If your editor is configured to use vi (the default setting) Type :set paste, then c, then Shift + G. This will clear out the default skeleton.
You will now be in insert mode. Press Shift + insert. This will paste in the script.
Now save the script by pressing Esc, then typing :wq < enter > and follow the prompts.
How to use this snippet:
Example
root@bigip(Active)(/Common)(tmos)# run cli script dns.monitor xxx Requires 5 arguments: := Name you want to give the monitor := A, NS, PTR, SOA, CNAME := What you are asking the DNS server (send string) := Why you expect for a "healthy" response (recv string) := The frequency you want the monitor to fire e.g. dns.monitor my_dns A www.example.com 192.0.2.55 5 root@bigip(Active)(/Common)(tmos)# run cli script dns.monitor my_dns A www.example.com 192.0.2.55 5 root@bigip(Active)(/Common)(tmos)# list ltm monitor udp my_dns ltm monitor udp my_dns { debug no defaults-from udp destination *:* interval 5 recv \\x00\\x01.*\\x04\\xc0\\x00\\x02\\x37 send \\x96\\x87\\x01\\x00\\x00\\x01\\x00\\x00\\x00\\x00\\x00\\x00\\x03www\\x07example\\x03com\\x00\\x00\\x01\\x00\\x01 time-until-up 0 timeout 16 } root@bigip(Active)(/Common)(tmos)#
Code :
create script dns.monitor { proc script::init {} { } proc script::run {} { if {$tmsh::argc == 6} { # create monitor set monitor_name [lindex $tmsh::argv 1] set monitor_type [string toupper [ lindex $tmsh::argv 2 ]] switch $monitor_type { A { set monitor_send [generate_monitor_send_string_a_record [lindex $tmsh::argv 3]] set monitor_recv [generate_monitor_recv_string_a_record [lindex $tmsh::argv 4]] } NS { set monitor_send [generate_monitor_send_string_ns_record [lindex $tmsh::argv 3]] set monitor_recv [generate_monitor_recv_string_ns_record [lindex $tmsh::argv 4] [lindex $tmsh::argv 3]] } PTR { set monitor_send [generate_monitor_send_string_ptr_record [lindex $tmsh::argv 3]] set monitor_recv [generate_monitor_recv_string_ptr_record [lindex $tmsh::argv 4]] } SOA { set monitor_send [generate_monitor_send_string_soa_record [lindex $tmsh::argv 3]] set monitor_recv [generate_monitor_recv_string_soa_record [lindex $tmsh::argv 4] [lindex $tmsh::argv 3]] } CNAME { set monitor_send [generate_monitor_send_string_cname_record [lindex $tmsh::argv 3]] set monitor_recv [generate_monitor_recv_string_cname_record [lindex $tmsh::argv 4] [lindex $tmsh::argv 3]] } default { usage } } set monitor_interval [lindex $tmsh::argv 5] set monitor_timeout [ expr { [ expr {$monitor_interval * 3} ] + 1 } ] # doctor the send and receive strings so that they go through as intended set monitor_send [doctor_hex_string $monitor_send] set monitor_recv [doctor_hex_string $monitor_recv] tmsh_create "ltm monitor udp $monitor_name defaults-from udp interval $monitor_interval timeout $monitor_timeout send \"$monitor_send\" recv \"$monitor_recv\"" } else { usage } } proc script::help {} { tmsh::add_help "Create a DNS monitor \n\" } proc script::tabc {} { } proc tmsh_create { arguments } { regsub -all {\[} $arguments "\\\[" arguments regsub -all {\]} $arguments "\\\]" arguments tmsh::create "$arguments" } proc number_to_hex_string { number } { if { $number < 0 } { set number [ expr {0 - $number} ] } set hex_string [format "\\x%02x" $number] return $hex_string } proc hostname_or_ip_address_to_dns_name { hostname } { set fields [split $hostname .] set dns_name "" foreach field $fields { set len [string length $field] set str_len [number_to_hex_string $len] append dns_name $str_len append dns_name $field } append dns_name "\\x00" return $dns_name } proc hostname_or_ip_address_to_reverse_dns_name { hostname } { set complete_hostname [format "arpa.in-addr.%s" $hostname] set fields [split $complete_hostname .] set dns_name "" foreach field $fields { # if [string is integer $field] { set len [string length $field] set str_len [number_to_hex_string $len] set dns_name [format "%s%s%s" $str_len $field $dns_name] # } } append dns_name "\\x00" return $dns_name } proc get_id { } { set value1 [expr { int(256 * rand()) }] set value2 [expr { int(256 * rand()) }] set id [number_to_hex_string $value1] append id [number_to_hex_string $value2] return $id } proc generate_dns_packet_payload { question } { set payload [get_id] append payload "\\x01\\x00" append payload "\\x00\\x01" append payload "\\x00\\x00" append payload "\\x00\\x00" append payload "\\x00\\x00" append payload $question return $payload } proc ip_addr_to_a_resp_addr { address } { set fields [split $address .] set num_fields 0 set field_encoding "" foreach field $fields { if {[string is integer $field]} { set num_fields [expr { $num_fields + 1 }] set part [number_to_hex_string $field] append field_encoding $part } } set dns_name [number_to_hex_string $num_fields] append dns_name $field_encoding return $dns_name } proc generate_send_payload { input_string record_type_code reverse } { if { $reverse == 0 } { set dns_name [hostname_or_ip_address_to_dns_name $input_string] } else { set dns_name [hostname_or_ip_address_to_reverse_dns_name $input_string] } set internet_address_qclass "\\x00\\x01" set question $dns_name append question $record_type_code append question $internet_address_qclass set send [generate_dns_packet_payload $question] return $send } proc generate_monitor_send_string_a_record { input_string } { set send [generate_send_payload $input_string "\\x00\\x01" 0] return $send } proc generate_monitor_send_string_ns_record { input_string } { set send [generate_send_payload $input_string "\\x00\\x02" 0] return $send } proc generate_monitor_send_string_ptr_record { input_string } { set send [generate_send_payload $input_string "\\x00\\x0c" 1] return $send } proc generate_monitor_send_string_soa_record { input_string } { set send [generate_send_payload $input_string "\\x00\\x06" 0] return $send } proc generate_monitor_send_string_cname_record { input_string } { set send [generate_send_payload $input_string "\\x00\\x05" 0] return $send } proc generate_monitor_recv_string_a_record { input_string } { set a_resp_addr [ip_addr_to_a_resp_addr $input_string] set recv [format "\\x00\\x01.*%s" $a_resp_addr] return $recv } proc generate_monitor_recv_string_ns_record { input_string domain_name } { regsub -all {\.} $domain_name \. domain_name set re [format "^(.*)(\.%s)$" $domain_name] set found [regexp $re $input_string matched new_hostname rest] if { $found != 0 } { set recv_temp [hostname_or_ip_address_to_dns_name $new_hostname] set re {^(.*\\)(x00)$} set found [regexp -nocase $re $recv_temp matched recv rest] if { $found != 0 } { set recv [format "\\x00\\x02.*%sxc0" $recv] } else { set recv [format "\\x00\\x02.*%s" $recv_temp] } } else { set recv [hostname_or_ip_address_to_dns_name $input_string] set recv [format "\\x00\\x02.*%s" $recv] } return $recv } proc generate_monitor_recv_string_ptr_record { input_string } { set dns_name [hostname_or_ip_address_to_dns_name $input_string] set recv [format "\\x00\\x0c.*%s" $dns_name] return $recv } proc generate_monitor_recv_string_soa_record { input_string domain_name } { regsub -all {\.} $domain_name \. domain_name set re [format "^(.*)(\.%s)$" $domain_name] set found [regexp -nocase $re $input_string matched new_hostname rest] if { $found != 0 } { set recv_temp [hostname_or_ip_address_to_dns_name $new_hostname] set re {^(.*)(\\x00)$} set found [regexp -nocase $re $recv_temp matched recv rest] if { $found != 0 } { set recv [format "\\x00\\x06.*%s(\\xc0|\\x05)" $recv] } else { set recv [format "\\x00\\x06.*%s" $recv_temp] } } else { set recv [hostname_or_ip_address_to_dns_name $input_string] set recv [format "\\x00\\x06.*%s" $recv] } return $recv } proc generate_monitor_recv_string_cname_record { input_string hostname } { regsub -all {\.} $hostname \. hostname #puts "hostname = $hostname" set re {^([^\.]+)\.(.+)$} #puts "re = $re" set found [regexp -nocase $re $hostname matched first domain_name] #puts "found = $found" if { $found == 0 } { set domain_name $hostname } regsub -all {\.} $domain_name \. domain_name #puts "domain_name = $domain_name" #puts "input_string = $input_string" set re [format "^(.*)(\.%s)$" $domain_name] #puts "re = $re" set found [regexp -nocase $re $input_string matched new_hostname rest] if { $found != 0 } { set recv_temp [hostname_or_ip_address_to_dns_name $new_hostname] set re {^(.*\\)(x00)$} set found [regexp -nocase $re $recv_temp matched recv rest] if { $found != 0 } { set re {^(.*)(\\x00)$} set found [regexp -nocase $re $recv_temp matched recv rest] set recv [format "\\x00\\x05.*%s(\\xc0|\\x05)" $recv] } else { set recv [format "\\x00\\x05.*%s" $recv_temp] } } else { set recv [hostname_or_ip_address_to_dns_name $input_string] set recv [format "\\x00\\x05.*%s" $recv] } return $recv } proc doctor_hex_string { input } { set pieces [split $input \\ ] set output "" set first_time 1 foreach piece $pieces { if { $first_time == 1 } { set first_time 0 } else { append output {\\} } append output $piece } return $output } proc usage { } { puts "Requires 5 arguments: \n\ := Name you want to give the monitor \n\ := A, NS, PTR, SOA, CNAME \n\ := What you are asking the DNS server (send string) \n\ := Why you expect for a \"healthy\" response (recv string) \n\ := The frequency you want the monitor to fire \n\n\ e.g. [lindex $tmsh::argv 0] A www.example.com 192.0.2.55 5" exit } }
