Problem this snippet solves:
This script polls the BIG-IP via SNMP and displays the current CPU utilization for each processor and the global utilization for all processors.
How to use this snippet:
  1. Install script on remote system with appropriate permissions.
  2. Make sure Perl and the Net::SNMP perl module are installed.
Code :
#!/usr/bin/perl -w
# This code is not supported by F5 Network and is offered under the GNU General Public License.  Use at your own risk.
use strict;
use Net::SNMP qw(:snmp);
my ($host, $snmp_comm);
$host = $ARGV[0];
$snmp_comm = $ARGV[1];
chomp ($host , $snmp_comm);
my $cpuIndex     = ".1.3.6.1.4.1.3375.2.1.7.5.2.1.2.1.48";
my $cpuUsageRatio5s = ".1.3.6.1.4.1.3375.2.1.7.5.2.1.19.1.48.";
my $cpuUsageRatio1m = ".1.3.6.1.4.1.3375.2.1.7.5.2.1.27.1.48.";
my $cpuUsageRatio5m = ".1.3.6.1.4.1.3375.2.1.7.5.2.1.35.1.48.";
my $gcpuUsageRatio5s = ".1.3.6.1.4.1.3375.2.1.1.2.20.21.0";
my $gcpuUsageRatio1m = ".1.3.6.1.4.1.3375.2.1.1.2.20.29.0";
my $gcpuUsageRatio5m = ".1.3.6.1.4.1.3375.2.1.1.2.20.37.0";
my ($session, $error) = Net::SNMP->session(
            -hostname       => $host,
            -community      => $snmp_comm,
            -port           => 161,
            -version        => 'snmpv2c',
            -nonblocking    => 0
if (!defined $session) {
        print "Received no SNMP response from $host\n";
        print STDERR "Error: $error\n";
        exit -1;
my $allCPU = $session->get_table ( -baseoid => $cpuIndex );
my %cpu_table = %{$allCPU};
my $x = 0;
print "\n\nCPU Utilization:\t5s\t1m\t5m\n\n";
foreach my $key (sort keys %cpu_table) {
my @oid_index = split(/\./, $key);
my $ltm_cpu5s = $cpuUsageRatio5s . $oid_index[-1];
my $ltm_cpu1m = $cpuUsageRatio1m . $oid_index[-1];
my $ltm_cpu5m = $cpuUsageRatio5m . $oid_index[-1];
my $oid_ratios = $session->get_request(
-varbindlist =>
[$ltm_cpu5s, $ltm_cpu1m, $ltm_cpu5m] );
print "\tCPU$x\t\t$oid_ratios->{$ltm_cpu5s}\t$oid_ratios->{$ltm_cpu1m}\t$oid_ratios->{$ltm_cpu5m}\n";
$x++;
my $oid_gratios = $session->get_request(
-varbindlist =>
[$gcpuUsageRatio5s, $gcpuUsageRatio1m, $gcpuUsageRatio5m] );
print "\tGlobal\t\t$oid_gratios->{$gcpuUsageRatio5s}\t$oid_gratios->{$gcpuUsageRatio1m}\t$oid_gratios->{$gcpuUsageRatio5m}\n\n\n";
Comments
jtimartins_3149
This is great but I'm getting an error at the same time I get the values, so Cacti will not generate graphs...
The error is:
Use of uninitialized value $allCPU in hash dereference at /usr/share/cacti/scripts/f5_bigip_cpun.pl line 39.
Can you help?
Thanks and regards, jtimartins
Version history
Last update:
‎12-Mar-2015 16:29
Updated by:
Contributors
