Better Round Robin
Problem this snippet solves:
Implements Round Robin LB to avoid CMP idiosyncracies
How to use this snippet:
Attach this iRule to virtual server
Code :
when RULE_INIT { set static::betterRoundRobinDebug 1 } when CLIENT_ACCEPTED { set betterRoundRobinPoolMemberPick [lindex [active_members -list [LB::server pool]] [expr {[table incr [virtual]_count] % [active_members [LB::server pool]]}]] if {$static::betterRoundRobinDebug} { log "LB Pool: [LB::server pool] - ActiveMembersList: [active_members -list [LB::server pool]] - Attempt to Pick: $betterRoundRobinPoolMemberPick" } pool [LB::server pool] member [lindex $betterRoundRobinPoolMemberPick 0] [lindex $betterRoundRobinPoolMemberPick 1] }
Tested this on version:
12.1Published Feb 15, 2017
