Another Bash script to backup a BIG-IP device.
The backup script is executed from the BIG-IP device and the UCS file created is copied to a remote SCP server. After the file has been copied, it is deleted locally. All the backup steps are logged to the local syslog.
https://github.com/pedrorouremalta/f5-backup
Published Feb 09, 2022
2 Comments
  • Nice! As you have shown in github the icall event manager is used but also you can schedule it with just a cronjob or the script except bash can be python as F5 has Python on it but for UCS file transfer bash seems the better option.
