Webtop RDP on Mac Problems
Hi all,
I’m not sure if this is the right category to post the question but here we go :
I’m an end user of a Web Top VPN with RDP as an published App. I’m using this from a mac book with 10.9.x OS on it. Once you click for RDP session launch – it goes full screen and locks you out completely. You cannot minimize the window (no option) or move away to another window to do anything. If I login via a Linux or Windows machine - it works fine but it’s just mac which is giving problem.
Also the keyboard mapping seems to be a problem where my Command button on mac isn’t giving me a Windows keys response like in Native MS Remote Desktop client.
Any help or work around for this would be much appreciated.
It’s known issue. The workaround is to use percent of desktop 100% instead of full screen in window size setting.
hi out there I know it is a stupid idea but it could solve your problem - run a dedicated Windows VM under virtualbox…
When I hit such a problem where it is caused by the platform I sometimes resign and use what is best for the purpose
