VS FORWARDING & ROUTE
Hello
Did we need to set a route when we use a vs forwarding even if the host distintation is directly connected to f5 BIG-IP .
I see that there is option ressource set to use vlan when we create a route .
Thanks a lot
Coridially
You do not need routes on the F5 if the subnet that the destination device is directly connected to the F5.
Thanks foe your response . So why the option use ressource vlan/tunnel does exist when we create new route in the f5 dowumentation said that when we use this option this mean that the network is direcrly connected
Use VLAN/Tunnel Select this option when you want the next hop in the route to be a VLAN or tunnel. This option works well when the destination address you specify in the routing entry is a network address. Selecting a VLAN/tunnel name as the resource implies that the specified network is directly connected to the BIG-IP system. In this case, the BIG-IP system can find the destination host simply by sending an ARP request to the hosts in the specified VLAN, thereby obtaining the destination host’s MAC address.
What is this configuration item associated to on the device?
