BIG-IP BGP Routing Protocol Configuration And Use Cases
Is the F5 BIG-IP a router? Yes! No! Wait what?
Can the BIG-IP run a routing protocol? Yes. But should it be deployed as a core router? An edge router?
Stay tuned. We’ll explore these questions and more through a series of common use cases using BGP on the BIG-IP… And oddly I just realized how close in typing BGP and BIG-IP are, so hopefully my editors will keep me honest. (squirrel!)
In part one we will explore the routing components on the BIG-IP and some basic configuration details to help you understand what the appliance is capable of. Please pay special attention to some of the gotchas along the way.
Can I Haz BGP?
Ok. So your BIG-IP comes with ZebOS in order to provide routing functionality, but what happens when you turn it on? What do you need to do to get routing updates in to the BGP process? And well does my licensing cover it? Starting with the last question…
tmsh show /sys license | grep “Routing Bundle”
The above command will help you determine if you’re going to be able to proceed, or be stymied at the bridge like the Black Knight in the Holy Grail.
Fear not! There are many licensing options that already come with the routing bundle.
Enabling Routing
First and foremost, the routing protocol configuration is tied to the route-domain. What’s a route-domain? I’m so glad you asked!
Route-domains are separate Layer 3 route tables within the BIG-IP. There is a concept of parent and child route domains, so while they’re similar to another routing concept you may be familiar with; VRF’s, they’re no
t quite the same but in many ways they are. Just think of them this way for now. For this context we will just say they are. Therefore, you can enable routing protocols on the individual route-domains. Each route-domain can have it’s own set of routing protocols. Or run no routing protocols at all.
By default the BIG-IP starts with just route-domain 0. And well because most router guys live on the cli, we’ll walk through the configuration examples that way on the BIG-IP.
tmsh modify net route-domain 0 routing-protocol add { BGP }
So great! Now we’re off and running BGP. So the world know’s we’re here right? Nope.
Considering what you want to advertise.
The most common advertisements sourced from the BIG-IP are the IP addresses for virtual servers. Now why would I want to do that? I can just put the BIG-IP on a large subnet and it will respond to ARP requests and send gratuitous ARPs (GARP). So that I can reach the virtual servers just fine.
<rant>
Author’s opinion here: I consider this one of the worst BIG-IP implementation methods. Why? Well for starters, what if you want to expand the number of virtual servers on the BIG-IP? Well then you need to re-IP the network interfaces of all the devices (routers, firewalls, servers) in order to expand the subnet mask. Yuck! Don’t even talk to me about secondary subnets.
Second: ARP floods! Too many times I see issues where the BIG-IP has to send a flood of
GARPs; and well the infrastructure, in an attempt to protect its control plane, filters/rate limits the number of incoming requests it will accept. So engineers are left to try and troubleshoot the case of the missing GARPs
Third: Sometimes you need to migrate applications to maybe another BIG-IP appliance as it grew to big for the existing infrastructure. Having it tied to this interface just leads to confusion.
I’m sure there’s some corner cases where this is the best route. But I would say it’s probably in the minority.
</rant>
I can hear you all now… “So what do you propose kind sir?”
See? I can hear you…
Treat the virtual servers as loopback interfaces. Then they’re not tied to a specific interface. To move them you just need to start advertising the /32 from another spot (Yes. You could statically route it too. I hear you out there wanting to show your routing chops.) But also, the only GARPs are those from the self-ip’s
This allows you to statically route of course the entire /24 to the BIG-IP’s self IP address, but also you can use one of them fancy routing protocols to announce the routes either individually or through a summarization.
Announcing Routes
Hear ye hear ye! I want the world to know about my virtual servers. *ahem*
So quick little tangent on BIG-IP nomenclature. The virtual server does not get announced in the routing protocol. “Well then what does?”
Eery mind reading isn’t it? Remember from BIG-IP 101, a virtual server is an IP address and port combination and well, routing protocols don’t do well with carrying the port across our network. So what BIG-IP object is solely an IP address construct? The virtual-address!
“Wait what?” Yeah… It’s a menu item I often forget is there too. But here’s where you let the BIG-IP know you want to advertise the virtual-address associated with the virtual server. But… but… but… you can have multiple virtual servers tied to a single IP address (http/https/etc.) and that’s where the choices for when to advertise come in.
tmsh modify ltm virtual-address 10.99.99.100 route-advertisement all
There are four states a virtual address can be in: Unknown, Enabled, Disabled and Offline. When the virtual address is in Unknown or Enabled state, its route will be added to the kernel routing table. When the virtual address is in Disabled or Offline state, its route will be removed if present and will not be added if not already present. But the best part is, you can use this to only advertise the route when the virtual server and it’s associated pool members are all up and functioning. In simple terms we call this route health injection. Based on the health of the application we will conditionally announce the route in to the routing protocol.
At this point, if you’d followed me this far you’re probably asking what controls those conditions. I’ll let the K article expand on the options a bit. myF5
“So what does BGP have to do with popcorn?”
Popcorn? Ohhhhhhhhhhh….. kernel! I see what you did there!
I’m talking about the operating system kernel silly. So when a virtual-address is in an unknown or enabled state and it is healthy, the route gets put in the kernel routing table. But that doesn’t get it in to the BGP process. Here is how the kernel (are we getting hungry?) routes are represented in the routing table with a ‘K’
This is where the fun begins! You guessed it! Route redistribution? Route redistribution!
And well to take a step back I guess we need to get you to the ZebOS interface.
To enter the router configuration cli from the bash command line, simply type imish. In a multi-route-domain configuration you would need to supply the route-domain number but in this case since we’re just using the 0 default we’re good. It’s a very similar interface to many vendor’s router and switch configuration so many of you CCIE’s should feel right at home. It even still lets you do a write memory or wr mem without having to create an alias. Clearly dating myself here..
I’m not going to get in to the full BGP configuration at this point but the simplest way to get the kernel routes in to the BGP process is simply going under the BGP process and redisitrubting the kernel routes.
BUT WAIT! Thar be dragons in that configuration!
First landmine and a note about kernel routes. If you manually configure a static route on the BIG-IP via tmsh or the tmui those will show up also as kernel routes
Why is that concerning? Well an example is where engineers configure a static default route on the BIG-IP via tmsh. And well, when you redistribute kernel routes and that default route is now being advertised into BGP. Congrats! AND the BIG-IP is NOT your default gateway hilarity ensues. And by hilarity I mean the type of laugh that comes out as you’re updating your resume.
The lesson here is ALWAYS when doing route redistribution always use a route filter to ensure only your intended routes or IP range make it in to the routing protocol. This goes for your neighbor statements too. In both directions! You should control what routes come in and leave the device.
Another way to have some disasterous consequences with BIG-IP routing is through summarization. If you are doing summarization, keep in mind that BGP advertises based on reachability to the networks it wants to advertise. In this case, BGP is receiving it in the form of kernel routes from tmm. But those are /32 addresses and lots of them! And you want to advertise a /23 summary route. But the lone virtual-address that is configured for route advertisement; and the only one your BGP process knows about within that range has a monitor that fails.
The summary route will be withdrawn leaving all the /23 stranded. Be sure to configure all your virtual-addresses within that range for advertisement.
Next: BGP Behavior In High Availability Configurations
Awesome, thanks for sharing  @Brandon  ! But I have a very important question…is that Kent from Real Genius for an avatar?
Why yes  @JRahm … Yes it is. By far my favorite movie ever.
you are now 10x cooler than you already were. I love that movie so much…and I love it that Laslo = Uncle Rico in Napoleon Dynamite.
LoL… I’ll have to work Laslo in to the next one in the series
Thanks for the article @Brandon
In my case, I have a single VIP which is a /32 route. My VIP is 192.168.100.100/32, but I want to advertise a summary route, like you’ve stated in your article. I used the imish command “aggregate-address 192.168.100.0/24” which does the trick. Now, the /24 route is advertised, not the /32. Great.
My problem is that both the Active and the Standby unit are advertising this route with equal weight, so I am seeing my BGP neighbors with 2x next hops for this VIP range (the self IP of the Active, and that of the Standby).
My client connections are working about 50% of the time :slight_smile:
What am I doing wrong?
I seem to have a workaround, although I still need clarification on the recommended way to do this.
I believe I have 4 ways to share a route with my BGP neighbors from BIG-IP. In each case I need to run “redistribute kernel” and, as you point out, use a route map to filter out the 0.0.0.0/0 route and perhaps others I don’t want to share, so that I don’t send the BIG-IP’s default route to the BGP peers and take down the network.
a) I can use the imish command “network 192.168.100.0/24” when configuring BGP on BIG-IP, as is done in this KB article from F5.
b) I could create a static route to share, using F5 GUI or tmsh. However, since I can’t set a next hop IP address to my own self IP, I don’t think this can help me when creating a VIP range to redistribute.
c) I could create a /32 VIP and use the imish command “aggregate-address 192.168.100.0/24”, as is done this lab from F5. I think this is what you mean when you say we should summarize routes.
d) I can create a VIP where the VirtualAddress is 192.168.100.0/24 and set Route Advertisement to Enabled. It’s a single VIP, and the imish command “show ip route” shows that it’s directly connected to my Active device, and not my Standby.
I think that only option D gets me the VIP range advertised from the Active device only. Options A,B,C all seem to lead to the situation where both Active and Standby devices are advertised as equally-weighted next hops for the route.
Am I right?
Well hello there Michael and thank you for stumbling on my article. I had the intention to write more of the series, but as there really wasn’t a lot of feedback I didn’t think anyone really wanted to hear from me. My goal was to cover how HA behavior works with BIG-IP and BGP in the second in the series. And well, your questions inspired me to pick this back up.
But to quickly summarize. If a BIG-IP HA-Pair is set up properly the kernel routes should only show up in the routing table IF the BIG-IP is active. The standby for the traffic-group will not have the kernel routes to redistribute.
This is why, in my lab which you also stumbled upon; I use aggregate-address. BGP is a different routing protocol in that it generally must learn a route from another routing protocol, or static, or in this case from the kernel. Without the /32 kernel route for the BGP process to learn something in the /24 aggregate it won’t advertise the /24. This would leave me to believe that the /32 is active in the kernel on both devices which is why you saw it advertised from both.
One fun fact. When you use aggregate-address it will install a /24 route to null0 in the routing table to advertise. This is also why if there are individual VIPs in the range they all should have advertisement enabled assuming you don’t want the route withdrawn if any particular /32 fails.
Above: Note the ‘active’ state and the ‘K’ route (and route to null0)
Below: Note the ‘Standby’ state and no additional routes.
Now for a little bit on the difference between the network statement in BGP and the aggregate-address statement.
For the network statement to work by default back in the day, when dinosaurs configured routers with their little T-Rex hands there must be an exact match in the routing table.
I say by default; because that was the default behavior and many of us packet heads after configuring our BGP statement, the next immediate command was ‘no auto-summary’. Which now is the default and doesn’t show up in the configuration anymore.
So now, let’s look at your other suggestion of creating a /24 virtual server.
A lot of times, the /24 virtual server gets created as a “catch all” for the subnet. This can be a good thing in that I can log what hits IPs within the range that don’t have a more specific virtual server attached to them. This is especially good if you’re migrating things around. Like an application moves over to another network and you can see if for some reason that route isn’t getting honored somewhere. There’s lots of ways to have fun with it.
And yes, if it’s tied to the failover traffic-group it will only be a kernel route on the active device. The problem will be that the route won’t be withdrawn without some failure situation. In this case I would think about creating a pool and assign a monitor with an alias configuration that monitors something downstream.
Shame on me! I’ve been sitting here patiently waiting on the next installment.
I am currently putting off a BGP config due to HA and lack of clear guidance, I should have just asked!
In my world, I don’t control the upstream neighbor router, so it’s something I have to plan extensively.
Simple First Question:
When forming a neighbor-ship with the upstream router, and I have a 2 - i7820 HA pair, do I give them the Floating IP? Or do I build basically two neighbors, one in each physical i7820 with their non-floating IP?
Oh my! Now I’m getting motivated to finish part 2 which is focused on how HA works with a BIG-IP and BGP. So thanks for validating that there’s some value there.
So to answer your question @TSSRShot
When forming neighbor relationships with upstream routers, you will establish the neighbor with the local self-IP on each BIG-IP. So the router will have two neighbor statements and the BIG-IP will have 1 or 2 depending on your upstream configuration.
The value of the floating self-IP in this arrangement is that the Active router will advertise the networks you want with a next-hop of the floating self-IP.
Now why would that be good? Well in a failover scenario the next-hop doesn’t change. So no matter which router is Active, the next-hop and all flows associated with it won’t change. The upstream routers don’t need to learn the new next-hop and redirect traffic that way so any flows in-flight aren’t interrupted.
@MichaelOLeary was nice enough to link to a BGP lab I developed and taught a couple years ago at our user conference. Its retirement is the inspiration for this intended series and it might help you with some additional thoughts. But feel free to fire away questions while I diligently come up with smart-alecky things to say for the second installment.
hi, pardon me for jumping in… but also was waiting for part 2 and neglected to reply to show my active interest… thank you for this article and all the follow up comments!
here are a few comments/questions I also have:
  • ospf vs bgp? and more specifically, if the big-ip is “inline” with the server subnet, any thoughts on using nssa configuration in ospf vs bgp aggregation/summarization to keep route tables optimized? since servers are all south of the big-ip and external/default/client routes all have to go north to the border router/firewall
  • differences in behavior for HA in ospf vs bgp, and any pros/cons of each
  • we are using a combination of ospf/nssa within a DC and ibgp across to the second DC via DCI link, with traffic groups shared across both DC big-ip’s so we can “float” a VIP from one DC to the other and maintain a single configurations… virtual server, pool, monitor, etc. but this has also had side effect on bgp announcing the floating self-IP, and basically breaks this behavior… any thoughts/suggestions on a better approach?
  • we’re now looking at taking the big-ip and moving it to another part of the DC network, north of the border router/firewall, and not fully inline anymore but still inline for traffic related to the VIP - note we are avoiding snat and that is why we are inline or want to be inline - and then using bgp neighborship to each border router/firewall and the WAN fabric routers to attract/inject VIP traffic and policy based symmetric return from the border router/firewall - again avoiding snat
  • any dependencies/limitations on bgp or ospf with big-ip next?
sorry if my comments/questions seem all over the place but we have been using routing for several years now and planning to migrate in the coming months/years to even more iterations of routing/rhi together with a fabric/vxlan based DC/DCI… so am very interested in any/all comments and articles you come up with… thanks in advance for considering my input to the topic
To close the loop on this. More than likely the reason you were seeing the /24 from both locations is that while iBGP tells you that you need a full mesh and all iBGP routers should be peered. This is the one case where the two BIG-IPs should not be neighbors.
iBGP will advertise the route to the other BIG-IP. Then because the router is peered to an eBGP neighbor it will advertise it as well.
B       192.168.123.0/24 [200/0] via 10.1.10.22, client, 00:00:03
Now if you’re using a floating self-IP, they will both advertise it with the next-hop the same so the routing table will just install one route. But without the next-hop modification it will show up from both devices.
Welcome @wtwiggs
Let’s see if I can distill down your questions.
Well now we get in to some religious talk. At least it’s less contentious than a political discussion.
OSPF and BGP have a long history of fighting over who is right and who’s going to be the routing protocol of the data center. It’s been a bloody battle, but there’s a couple things to keep in mind. BGP generally needs to learn it’s routes from somewhere else like an IGP. e.g. OSPF The usual argument is that OSPF has faster convergence, but there are timers that can be tuned if BGP convergence needs to happen quickly.
So if you’re already set with running OSPF internally, and between security zones and OSPF and it’s scaling for you then keep it up. I often recommend to people to think of the BIG-IP as and ASBR. In the OSPF case where you’re set up as an NSSA that makes sense especially if you’re advertising routes for the server networks behind it without knowing your network specifically it could likely just be a stubby area.
BGP works in providing separation of autonomous systems in the same way as OSPF areas. It also works well when the router team and the BIG-IP team aren’t the same so the controls can be implemented in BGP similar to an ISP and a customer.
BGP and OSPF implementations both advertise the route from the active device if implemented properly. In Michael’s case there’s a slight deviation in the iBGP design consideration for a full mesh if you’re not using a floating Self-IP in that you don’t want to establish a neighbor relationship between the two BIG-IPs.
I’m thinking a diagram would be better here. From what you’re describing I would be concerned with asymmetric traffic flows without SNAT unless you’re doing DSR. But it seems like you’re trying to solve it with PBR? PBR is an established way to do this. You create tunnels to the servers and the return traffic bypasses the BIG-IP. That of course means you need to play nice with the server team. :slight_smile:
I don’t think OSPF is available yet in BIG-IP v20/Next. So there’s that.
It’s been on my list to dig in to Next’s BGP implementation a bit deeper, but I’m clearly running behind. I was consulted on some of the design/planning work and peeked at the final. It’s in there and from what I’ve seen it’s full featured. I know there’s some changes coming to Next, so I’d give it a little time for the dust to settle.
So I’ve since learned that the upstream org will not provide an extra IP for a floating IP. Basically I get 2 x P2P circuits and a /30 each.
Am I sunk? Just going to have to accept minor loss during change over actives?
Sunk is such a negative word. This is a happy place. :slight_smile:
From what it sounds like you’re looking at each BIG-IP device in a cluster peered with a different external router across the /30 links?
Good question, I apologize, I didn’t paint a very good picture.
We have an active pair of i7820 in HA. Each unit has a single IP (/30) to an upstream HA router pair.  Kind of like a single circuit into each F5. Behind our F5s we have amazingly good amounts of routable IPs, so VS’s have their own dedicated IP (when fitting) and tons of pool nodes. We summarize a /22 to a /30 right now.
The upstream provider isn’t a vendor. And they refuse to resubnet. lol I even offered some of our internal IPS to sacrifice. The only idea they offer is an external switch that I BGP between them and the F5s…which is a single source of failure.
Gotcha. I think then yes. You will need to rely on route reconvergence to happen which might disrupt some traffic flows briefly. What might make sense is to adjust the bgp timers to reduce that a little.
I’m testing similar setup in our environment and want to check with you the best approach. I have 2 kind of design that I want to do. 1 is front and backend in same vlan and other one on 2 different vlans(Topology attached). I’ll be using 2 seperate vlan to connect to 2 switch and running BGP over it. Expectation is there wont be a connection drop in the event of a switch failure or BIG-IP failure.
These are the thing I did inorder to make it work. I want to check with you if there is any better way to do this.
  1. Attached a SNAT to the Virtual Server(Standard type) and advertised to BGP.
  2. SNAT, I created as standard type virtual server inorder to get them in kernel and redistribute to BGP.
  3. Disabled Autolast hop.
  4. Disabled vlan keyed connection
  5. Enabled connection mirroring for the Virtual server.
  6. In BGP, I disabled graceful restart and enabled BFD.
  7. All of them are ebgp and I have set BGP advertise interval to 0 inorder to advertise updates as quickly as possible.
I found and article online myF5, that state to enable loose close/initiation enabled for fastl4 protocol profile. But in my case I have the virtual servers including SNAT configured as type standard.
I want to do the same thing with GTM. Do you have any suggestions here?
