Hello,
If I have a Virtual Server that uses the Single Node Persistence Profile under /Common (for the Default Persistence Profile).
I also have an iRule on the same Virtual server that will go to a different Pool if a specific path is in the request (i.e. /xyz).
For the one pool (not the default for the VS) referenced in the iRule, I would like to have some form of persistence/stickyness. Would that be possible since the VS uses the Single Node Persistence Profile?
My problem is that I need some form of stickyness for the Pool that path /xyz will leverage (i.e. go to the same node for the clients requests).
It appears (and, sort of, makes sense) that by using Single Node Persistence, this would not be possible.
Can you confirm this (or deny) and please recommend a possible solution?
Thank you!!
-Tom
