Variable assignment in irule
Dear All,
I need to set an irule variable in the HTTP_RESPONSE based on a condition, and make a decision on the next HTTP_REQUEST based on the variable value and unset the variable.
The problem is that the variable value that was set on HTTP_RESPONSE does not get reflected in the next HTTP_REQUEST. What should I do to make the variable hold its value.
example:
when HTTP_REQUEST { if { [ info exists var] and $var eq 1 }{
do something
unset var } }
when HTTP_RESPONSE { if { [HTTP::status] contains 302 and [HTTP::header “Location” ] eq “/vdesk/hangup.php3” } { set var 1 } }
Hi Guy,
use a custom session variable in your iRule like the following:
if { [ACCESS::session data get session.custom.var] eq "1" }{
    do something
    ACCESS::session data set session.custom.var ""
if { [HTTP::status] contains 302 and [HTTP::header "Location" ] eq "/vdesk/hangup.php3" }
    ACCESS::session data set session.custom.var "1"
The problem with your code is the next request can be in a different tcp connection… so the variable is not shared between response and request…
Http response can be with http 1.0 version which means the tcp connection close just after response…
You have the opportunity to use the functionnality (OTP Verify) in vpe that allow you to activate 5 attempts. Or create via an empty box your need (verify your otp with loop:5)
First of you use F5 native solution? for OTP.
Why you can’t use OTP Verify that allow you 5 attempts…
regards
