The same static variable in different iRules/VS
I have a static variable set in iRule named rule-http:
when RULE_INIT {
set static::variable “first_value”
This iRule rule-http is applied to virtual server VS-1 (1.2.3.4:80) - used in production very often
I prepared second iRule named rule-http-new, with the same variable name set to a different value:
when RULE_INIT {
set static::variable “second_value”
and applied it to VS-2 (1.2.3.5:80) - it will be used in the future, now only tested couple of times, not processing much data
I assumed that when client request hits VS-1, rule-http is processed and regardless of the previous value, the static::variable is set to “first_value”. And that the last set value will remain in the system until next change or reload. Or Am I wrong? Because in real, the value of static::variable remains set to “second_value” and other events of the iRule rule-http are not processed as expected.
ver. 17.5.1.3
Thank you for clarification.
Hello @Pytonius
static variables might became very tricky
So first of irule init does not execute on a request base but every time the irule is initiated (saved, applied, etc)
That said if the last action you did was in second irule, that variable preserved
OK, that is interesting. So the most deterministic approach is to have only 1 iRule in whole system with RULE_INIT for static variable definitions (maybe not applied in any VS) and all other iRules just referencing those variables without the ambitions to change any of them. So I rather stay with local variables :-)
Thank you again, Injeyan!
Hi @Pytonius ,
if they are really static and you need to access them from different iRules, why not store them in a datagroup?
KR
Daniel
