Dealing with iRule $variables for HTTP2 workload while HTTP MRF Router is enabled
Hi Folks,
I like to start a discussion on how to deal with iRule $variables, which are traversing independed iRule events, in combination with HTTP2 workload and HTTP MRF Router enabled (e.g. HTTP2 Full-Proxy mode or optionally for HTTP2 Gateway mode).
In detail I like to discuss the observation and some solutions while doing those things within an iRule:
  • Analyse a received HTTP2 request
  • Switch Pools based on the requested HTTP2 request
  • Switch Server-Side SSL Profiles based on the HTTP2 request
  • Inject a SNI-Value to the Server-Side CLIENTHELLO based on the free-text value (e.g. [HTTP::host]).
For HTTP/1.x workload this was basically bread and butter stuff and didn’t required me to understand any rocket science. But in HTTP2 those rather simple tasks have somehow changed…
Some background information on HTTP2 iRules
In HTTP2 a single TCP connection will be used to carry multiple HTTP2 streams in parallel.
- Client-Side TCP Connection
  - HTTP2 stream ID 1 (Request for /)
  - HTTP2 stream ID 3 (Request for /favicon.ico)
  - HTTP2 stream ID 5 (Request for /backgroung.jpg)
To handle such parallel HTTP2 streams on a single TCP connection, LTM got some interesting changes for HTTP2 workloads, which affects the way $variables are seperated and used within iRules.
The iRule snipped below will ilustrate the change…
when CLIENT_ACCEPTED {
	set var_conn 1
	incr var_conn
	log local0.debug $var_conn
In the traditional HTTP/1.x world, the number stored in the $var_conn variable would have been increased with every keep-alive’ed HTTP request send through the same TCP connection.
But this is not the case when dealing with HTTP2 workload while the HTTP MRF Router is enabled. The iRule snipped above will always log “2” independently of the total number of HTTP2 streams already send over the very same TCP connection.
When HTTP MRF Router is enabled, an individual HTTP2 stream will always create its own “child” $varibale environment while using the TCP connection environment as a carbon copy to inherit its $variables. The $variables within a given HTTP2 stream are staying isolated for the entire duration of the HTTP2 stream (including its Response) and wont mix up with $varibales of other HTTP2 streams or the $variables of the underlying TCP connection.
So far so good…
Info: The text above is only valid for HTTP MRF Router enabled HTTP2 workload. HTTP2 gateway mode without HTTP MRF Router enabled behaves slighly different. When HTTP MRF Router is disabled, an individual HTTP2 stream will be assigned to a child environment based on a bunch of “concurrently active HTTP2 streams” . The observation and problems outlined below are not valid for scenarios where HTTP MRF Router is disabled. Without using the HTTP MRF Router you wont run into the issues discussed below…
The “awkwardness” of the HTTP MRF Router
A challeging scenario (which has caused me sleepless nights) is show below…
	set conn_var 1
	set ssl_profile "MyCustomSSLProfile"
when SERVER_CONNECTED {
	if { [info exists ssl_profile] } then {
		catch { SSL::profile $ssl_profile }
		log local0.debug "No SSL Profile | Vars: [info vars]"
The log output will be always “No SSL Profile | Vars: conn_var”. The SERVER_CONNECTED event does somehow not have access to the $ssl_profile variable, which was just set by the HTTP_REQUEST event.
This implicitly means, that the SERVER_CONNECTED event is not getting executed in the carbon copied $variable environment of the HTTP2 stream which has triggered the LB decission to open a new connection..
Lets try to figure this out in which $variable environment the SERVER_CONNECTED event is executed…
	set x "Hello"
	set logstring ""
	if { [info exists x] } then { lappend logstring $x }
	if { [info exists y] } then { lappend logstring $y }
	log local0.debug $logstring
	set y "World"
The log output of the iRule above will be “Hello” on the first HTTP2 stream request and “Hello World” on consecutive HTTP2 streams which are received after the SERVER_CONNECTED event has been executed.
I immediately thought: “Okay, we must be back on the TCP connection layer environment during the SERVER_CONNECTED event!?!”
The first HTTP2 stream gets a carbon copy of the TCP connection environment after the CLIENT_ACCEPTED was executed with only $x set, then the SERVER_CONNECTED event adds $y to the TCP connection environment and subsequent HTTP2 streams getting then a carbon copy of the TCP connection environment with $x and $y set.
Sounds somehow reasonable… but then I tried this…
		log local0.debug $y
		log local0.debug "???"
	set y "Hello World"
The log output will be “???” on the initial HTTP2 stream (as expected). But after the SERVER_CONNECTED has been executed, the log will still continue output “???” on every subsequent HTTP2 stream (duh! wait? what?).
This behavior would basically mean that the SERVER_CONNECTED event is (in contrast to what I initially thought) not executed in the original $variable environment of the underlying TCP connection.
At this point, I can only assume what is happening behind the scenes: The SERVER_CONNECTED event is also running a carbon copy environment, where the orginal $variable environment of our TCP connection gets copied/ref-linked into (but ONLY if any $varibales where set) and any changes made to the carbon copy environment would become copied/ref-linked back to the orginal $variable environment of our TCP connection (but only if any $varibale where initially set).
With enough imagination this sounds at least explainable… but seriously… is it really working like that?
Note: At least SERVER_CONNECTED and all SERVERSSL_* related events are affected by this behavior. I did not tested if other events are affected too.
Question 1: If someone has insights what is happening here, or have other creative ideas to explain the outcome of my observations, I would be more than happy to get some feedback?  Its driving me nuts to get fouled by the iRules I’ve shown…
Lets discuss some solutions…
Disclaimer: Don’t use any of the iRule code below in your production environment unless you understand the impact. I crashed my dev environment more than once while exploring possiblities. Right now its way too experimental to recommend anything to use in production environment. And please dont blame me if you missed to read this warning… :wink:
I already reached the point where I’ve simply accepted the fact, that you can’t pass a regular $variable between a given HTTP2 stream and the SERVER_CONNECTED or SERVERSSL_* events. But i still need my job done and started to explore possibilities to interact between a HTTP2 stream and the server-side events.
My favorite solution so far exports an $array() varibale from the HTTP2 stream during LB_SELECTED to a [table -subtable] stored on the local TMM core. The SERVER_CONNECTED event will then lookup the [table -subtable] and restore the $array() variable.
	# Define a connection specific label
	set conn(label) "[IP::client_addr]|TCP::client_port|[IP::local_addr]:[TCP::local_port]"
	# Clean vars from previous requests
	unset -nocomplain temp conf
	# Define values for export
	set conf(SSL_Profile) "/Common/serverssl"
	set conf(SNI_Value) [HTTP::host]
when LB_SELECTED {
	# Export conf() to local TMM subtable
	if { [info exists conf] } then {
		if { [catch {
			# Try to export conf() to local TMM subtable
			table set -subtable $static::local_tmm_subtable \
								"$conn(label)|[HTTP2::stream]" \
								[array get conf] \
								indef \
								30
		}] } then {
			# Discover subtable on local TMM core (once after reboot)
			set tmm(table_iterations) [expr { [TMM::cmp_count] * 7 }]
			for { set tmm(x) 0 } { $tmm(x) < $tmm(table_iterations) } { incr tmm(x) } {
				set tmm(start_timestamp) [clock clicks]
				table lookup -subtable "tmm_local_$tmm(x)" [clock clicks]
				set tmm(stop_timestamp) [clock clicks]
				set tmm_times([expr { $tmm(stop_timestamp) - $tmm(start_timestamp) }]) $tmm(x)
			set static::local_tmm_subtable "tmm_local_$tmm_times([lindex [lsort -increasing -integer [array names tmm_times]] 0])"
			# Restart export of conf() to local TMM subtable
								[array get conf] \
								indef \
								30
	# Import conf() from local TMM subtable
	clientside {
		catch {
			array set conf [table lookup \
								"$conn(label)|[HTTP2::stream]"]
	if { [info exists conf(SSL_Profile)] } then {
		catch { SSL::profile $conf(SSL_Profile) }
		SSL::profile disable
when SERVERSSL_CLIENTHELLO_SEND {
	# Inject SNI Value based on conf() variable
	if { [info exists conf(SNI_Value)] } then {
		SSL::extensions insert [binary format SSScSa* \
												0 \
												[expr { [set temp(sni_length) [string length $conf(SNI_Value)]] + 5 }] \
												[expr { $temp(sni_length) + 3 }] \
												0 \
												$temp(sni_length) \
												$conf(SNI_Value)]
Beside of the slightly awkward approach to store things in a [table -subtable] to interact between the iRule events. An error message will be raised everytime you save the iRule.
Dec 15 22:17:44 kw-f5-dev.itacs.de warning mcpd[5551]: 01071859:4: Warning generated : /Common/HTTP2_FrontEnd:167: warning: [The following errors were not caught before. Please correct the script in order to avoid future disruption. "{badEventContext {command is not valid in current event context (SERVER_CONNECTED)} {5213 13}}"5105 132][clientside {
During iRule execution it seems to be absolutely fine to call the [clientside] command during SERVER_CONNECTED event to access the [HTTP2::stream] id which tiggered the LB_SELECTED event.
Question 2: Do you know other approches to deal with the outlinied MRF HTTP Router awkwardness? Do you have any doubts that the approach above may run stable? Do you have any tips how to improve the code? Should I be concerned that MCPD complaining about the syntax, or simply wrap [clientside] into an [eval $cmd] to trick out MCPD?
I know the post got basically “tl;dr” long, but this problem bothers me pretty much. A customer is already waiting for a stable solution… :disappointed_face:
Cheers, Kai
You are correct - the important point to note about MRF ( Message Routing Framework) is that client and server flows are in different contexts. This is actually the great strength of the MRF framework - a message could arrive on TCP and depart on UDP to multiple destinations. Loadbalancing is done based on message, not layer 4 connection. See https://clouddocs.f5.com/api/irules/MR.html
"MR iRule commands operate within a Tcl context associated with the connection flow between the endpoint and the MR proxy. The ingress and egress parts of a message’s journey therefore operate in separate Tcl contexts. The Tcl context contains the Tcl variables and execution state of the currently executing iRule event. Only one iRule event can execute at a time on a connection flow, therefore messages queue to execute their iRule events.
In many MR protocols, messages belong to independent transactions that are carried over the same network connection flow. It is highly desirable for messages sharing a connection flow to execute their iRules independently of other messages. This provides the following advantages and behavior changes:
  • A message does not need to wait for an unrelated message to complete an event in order to execute its own event.
  • Messages sharing a connection flow may exit the flow in a different order than they entered.
  • Tcl variables cannot be overwritten between events by another message."
To answer your question, you can either use the table as you have done, or use the MR::store and MR::restore commands to access clientside and serverside info from the opposite context.  See https://clouddocs.f5.com/api/irules/MR__store.html
Hey @PeteWhite ,
finally found some time to experiment with MR_INGRESS and MR_EGRESS event and the MR::store and MR::restore commands.
Unfortunately those two commands are neither able to copy/link a given variable from lets say the “HTTP_REQUEST” event to the “SERVER_CONNECTED” event. And also not from “SERVER_CONNECTED” to lets say “HTTP_REQUEST_RELEASE” event.
SERVER_CONNECTED and SERVERSSL_* behaving slightly weirdo. Could you please double check the information you’ve provided?
This simple test illustrates the issue…
	set CON_ID [TMM::cmp_unit][clock clicks]
	set REQ_ID ""
	log local0.debug "$CON_ID|$REQ_ID"
	set REQ_ID [TMM::cmp_unit][clock clicks]
when REMAINING_EVENTS {
Log output:
tmm1[17801]: Rule <CLIENT_ACCEPTED>: 11674705152203080|
 tmm1[17801]: Rule <HTTP_REQUEST>: 11674705152203080|11674705152236713
 tmm1[17801]: Rule <MR_INGRESS>: 11674705152203080|11674705152236713
 tmm1[17801]: Rule <LB_SELECTED>: 11674705152203080|11674705152236713
 tmm1[17801]: Rule <SERVER_CONNECTED>: 11674705152203080|
 tmm1[17801]: Rule <SERVERSSL_CLIENTHELLO_SEND>: 11674705152203080|
 tmm1[17801]: Rule <SERVERSSL_SERVERHELLO>: 11674705152203080|
 tmm1[17801]: Rule <SERVERSSL_SERVERCERT>: 11674705152203080|
 tmm1[17801]: Rule <SERVERSSL_HANDSHAKE>: 11674705152203080|
 tmm1[17801]: Rule <MR_EGRESS>: 11674705152203080|11674705152236713
 tmm1[17801]: Rule <HTTP_REQUEST_RELEASE>: 11674705152203080|11674705152236713
 tmm1[17801]: Rule <HTTP_RESPONSE>: 11674705152203080|11674705152236713
 tmm1[17801]: Rule <HTTP_RESPONSE_RELEASE>: 11674705152203080|11674705152236713
Adding MR::store and/or MR::restore wont make any difference. The SERVER_CONNECTED and SERVERSSL_* events wont see the $var added by HTTP_REQUEST…
Cheers, Kai
Hi Pete,
Somehow found the cause of the variable glitch an a final workaround for my problem.
If you set any local variables during the CLIENT_ACCEPTED event then the outlined strange variable beharior happens.
If you dont set any variable during the CLIENT_ACCEPTED event, then the HTTP_REQUEST event is able to pass variables to the SERVER_CONNECTED and SERVERSSL_* events and you can also pass variable out of those events to the HTTP_REQUEST_RELEASE event.
Looks like a very annoying bug. I would love to open a new case, but my MVP support contract just has become outdated… 🤐
Cheers, Kai
Hi Kai,
many thanks for this article. I have read it some time ago and now I stumbled over the exact same problem and can confirm your observations.
The issue occurs also if you set a local variable in the CLIENTSSL_CLIENTHELLO event. I have not checked other client side events.
I use this event to read the client side SNI header, do some custom logic based on the value and insert it into the server side connection.
If it is really a bug, it is not fixed with 17.5.1. Have you ever opened a case for this issue?
Best regards, Jürgen
I never opened a case for this issue. I’m more or less fine understanding the issue and with the workaround i gave.
Cheers, Kai
Just for completeness: I opened a case for this issue. I am curios to see what the outcome is.
I am also experimented with MR::store and MR::restore. The MR_EGRESS event triggers after the SERVER_CONNECTED and SERVERSSL_CLIENTHELLO_SEND events and are therefor unusable.
My test iRule is below. As soon I set a variable in CLIENT_ACCEPT, CLIENTSSL_CLIENTHELLO or CLIENTSSL_HANDSHAKE the “var2” set in HTTP_REQUEST is not available in the SERVER_CONNECTED, SERVERSSL_CLIENTHELLO_SEND or HTTP_REQUEST_SEND, but in the HTTP_REQUEST_RELEASE event.
Another finding in my tests is that the HTTP_REQUEST_SEND event is not triggered as soon there is a HTTP/2 Profile (Server) attached, but this is another topic.
    #log local0. "Set var1 to client_accept"
    #set var1 "client_accept"
when CLIENTSSL_CLIENTHELLO {
    #log local0. "Set var1 to clientssl_hello"
    #set var1 "clientssl_hello"
when CLIENTSSL_HANDSHAKE {
    #log local0. "Set var1 to clientssl_handshake"
    #set var1 "clientssl_handshake"
    if { [info exists var1] } {
        log local0. "var1: $var1"
        log local0. "var1: not set"
    log local0. "Set var1 to http_request"
    set var1 "http_request"
    log local0. "Set var2 to http_request"
    set var2 "http_request"
when MR_INGRESS {
    if { [info exists var2] } {
        log local0. "var2: $var2"
        log local0. "var2: not set"
    MR::store var1
    MR::store var2
when MR_EGRESS {
    MR::restore var1
    MR::restore var2
when HTTP_REQUEST_SEND {
when HTTP_REQUEST_RELEASE {
I asked the support and got links to this two articles:
But this article here describes the behavior even better.
The “14.1 limitation” mentioned in the HTTP2 CloudDoc is a different issue. The SERVER_CONNECTED and SERVERSSL_* $varible “bug” is still in place in TMOS 17.x.
K24532424 describes the intended $varible scoping behavior for MRF scenarios, but does not cover the bug that happens is you already set any $variables during “CLIENT_ACCEPTED”.
You may ask F5-Support to repro this issue.
Cheers, Kai
I asked exactly this.
MR::store, MR::restore as well as most other MR::* command are broken for HTTP2 workloads. MRF-HTTP2 is a very purpose driven, optimized and stripped down MRF-Mode.
Regarding HTTP_REQUEST_SEND: You may check the HTTP2-MRF event flow observations i gathered during my DEBUG_PAGE explorations. Between the lines your will find the solution for this…
# Information: Dealing with Keep-Alive Sessions for HTTP2 is sometimes annoying. Restart your browser or kill connections
	#              via TMSH if you feel that LTM does not do what you want...
	# CLIENT_ACCEPTED
	# CLIENTSSL_CLIENTHELLO
	# CLIENTSSL_CLIENTCERT
	# CLIENTSSL_HANDSHAKE
	# CLIENTSSL_DATA_CS_INGRESS
	# Note: HTTP2::disconnect is badly needed to trigger CLIENTSSL_* events on every single request.
	#       Unfortunately Chromium will stall after 6 GOAWAY responses (used by HTTP2::disconnect) for up to 5 minutes, because of
	#       a well known bug (see Chromium bug tracker ID=1030255).
	#       You may use Fiddler Everywhere as MitM to get full HTTP2::disconnect support to dig into the CLIENTSSL_* events. But even
	#       then you will end up with limited DEBUG PAGE support because of lacking SSL Renegotiation to inject cookies backwards
	#       into the session.
	#       My best advise is to debug clientside SSL handshakes using HTTP/1 to get full a interactive experience.
	# HTTP_REQUEST
	# MR_INGRESS_CS (the event is called MR_INGRESS, but filtering is based on [IP::remote_addr] eq [IP::client_addr])
	# PERSIST_DOWN (async event)
	# LB_SELECTED (async event)
	# LB_FAILED (async event if error happens during SS connection establishment)
	# MR_FAILED (async event if error happens during SS connection establishment)
	# Note: LB_FAILED and MR_FAILED trigger at the same time. Both event allow HTTP2 based responses.
	# SERVER_CONNECTED
	# SERVERSSL_CLIENTHELLO_SEND
	# SERVERSSL_SERVERHELLO
	# SERVERSSL_SERVERCERT
	# SERVERSSL_HANDSHAKE
	# SERVERSSL_DATA_SS_EGRESS
	# Note: SERVERSSL_DATA_SS_EGRESS (the event is called SERVERSSL_DATA) get triggered when SSL::collect was called in SERVERSSL_HANDSHAKE
	#       It seems to be egress HTTP2.0 communication to the backend server to negotiate the HTTP2 session.
	# MR_EGRESS_SS (the event is called MR_EGRESS, but filtering is based on [IP::remote_addr] eq [IP::server_addr])
	# HTTP_REQUEST_RELEASE
	# Note: The HTTP_REQUEST_SEND event does not trigger for HTTP2 in GW mode (could be a bug). Only HTTP_REQUEST_SEND triggers.
	# SERVERSSL_DATA_SS_INGRESS
	# Note: SERVERSSL_DATA_SS_INGRESS (the event is called SERVERSSL_DATA) get triggered when SSL::collect was called in HTTP_REQUEST_RELEASE
	#       It seems to be ingress HTTP2.0 communication from the backend server.
	#       The event is able to receive a cookie header via variable, but you can not pass information to other events via table nor variables (at least not stable!).
	#       Using static:: namespace allows a stable cross communication to the HTTP RESPONSE event to become able to deliver the page.
	# HTTP_RESPONSE
	# MR_INGRESS_SS
	# MR_EGRESS_CS
	# HTTP_RESPONSE_RELEASE
	# Note: Using the DEBUG PAGE for event trigger after HTTP_RESPONSE_RELEASE is not possible, because we wont get a chance
	#       to send a HTTP response after this event has been triggered.
	#       You may still trigger the page on those event an store the HTLM to [table] and review the content later,
	#       but this is not very useful.
	# CLIENTSSL_DATA_CS_EGRESS
	# Note: CLIENTSSL_DATA_CS_EGRESS (the event is called CLIENTSSL_DATA) get triggered when SSL::collect was called in HTTP_RESPONSE_RELEASE
	#       It seems to be egress HTTP2.0 communication to the client.
Note: Whenever you see *_CS and *_SS or even *_CS_INGRESS  and *_CS_EGGRESS event names. It means that a given even triggers more tan once during a single HTTP Request/Response.
Drop me an E-Mail and I will give you a personal DEBUG_PAGE session for HTTP2 with MRF-Router
Cheers, Kai
I already gave up using MR:: commands and I also do not use MR_* events. I want iRules that work independently from the HTTP version.
F5 support already confirmed that the HTTP_REQUEST_SEND event is not triggered with HTTP2 MRF-Router, but this is only internally documented. The MR_EGRESS event should be used instead, unfortunately this event does not support all the iRule commands HTTP_REQUEST_SEND supports.
Support confirmed that this behavior is not desired and it is a bug that will be fixed. The bug id is 2064069.
@Kai_Wilke
This is the bug. The SERVER_CONNECTED event should never see variables set in the HTTP_REQUEST event. I’m afraid that once the bug is fixed, your workaround will not work anymore and you must use tables.
So you asking for a fix that is making it even worse? I will most likely raise a bug report after your fix has been implemented…
For your Information: The [table] approach in my initial post depends on calling a [clientside] command during SERVER_CONNECTED. This command is unfortunately blocked by the iRule syntax checker, so that you have to wrap those commands into a [eval $cmd] dirty-hack. I will definately not recommend to use such hack in a production environment.
Cheers, Kai
No, I asked what the desired behavior is, and yes, the current situation is better than with the fix. I also want to use variables set in CLIENT_ACCEPT and HTTP_REQUEST in the SERVER_CONNECTED event.
bug ID?
