Until I can figure out this iControl stuff, I just need to put the information from the performance screens into a report. My question is where is this stored in the OS and is there a way to easily extract the information into report format?
Since this doesn’t deal with iRules or iControl, this is the kind of question I’d probably direct to technical support. They’ll be able to provide you with the help needed.
Colin
