Hello,
When verifying bigip.conf file, an error is reported about a network route. But the error has no reason to be there. Here is the error:
load sys conf file /config/bigip.conf verify Validating system configuration…
. . Validating configuration… /config/bigip.conf 01070330:3: Static route gateway 10.10.99.254 is not directly connected via an interface. Unexpected Error: Validating configuration process failed.
When I then exit tmsh and look at my network configuration I see that 10.10.99.254 is on the same network as one of my interfaces.
netstat -rn
Kernel IP routing table Destination Gateway Genmask Flags MSS Window irtt Iface 192.168.1.0 0.0.0.0 255.255.255.252 U 0 0 0 HA
127.1.1.0 0.0.0.0 255.255.255.0 U 0 0 0 tmm0
127.3.0.0 0.0.0.0 255.255.255.0 U 0 0 0 mgmt_bp
192.168.20.0 0.0.0.0 255.255.255.0 U 0 0 0 vlan20
192.168.2.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
10.220.220.0 0.0.0.0 255.255.255.0 U 0 0 0 vlan220
10.194.94.0 0.0.0.0 255.255.255.0 U 0 0 0 vlan194
127.2.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0.1
10.10.96.0 0.0.0.0 255.255.252.0 U 0 0 0 vlan1 &&&& LOOK HERE &&&&
0.0.0.0 10.10.99.254 0.0.0.0 UG 0 0 0 vlan1
This configuration is up and running. I can even ping 10.10.99.254… I am just worried this error hides something more serious. fyi we run version BIG-IP 11.3.0 Build 3144.51 Engineering Hotfix HF8
thanking you in advance
Alberto
