SSL handshake errors
Hi there,
Recently put TMOS version 12 into production and see following SSL handshake errors, none of which existed in version 10.2.3:
Nov 12 03:15:36 dc1lbc2p info tmm[11446]: 01260013:6: SSL Handshake failed for TCP 72.238.29.206:60819 → x.x.x.x:443 Nov 12 03:15:55 dc1lbc2p info tmm[11446]: 01260013:6: SSL Handshake failed for TCP 96.241.137.52:50815 → x.x.x.x:443 Nov 12 03:16:12 dc1lbc2p info tmm[11446]: 01260013:6: SSL Handshake failed for TCP 166.172.187.30:38119 → x.x.x.x:443 Nov 12 03:16:32 dc1lbc2p warning tmm[11446]: 01260009:4: Connection error: hud_ssl_handler:1135: codec alert (20) Nov 12 03:16:32 dc1lbc2p info tmm[11446]: 01260013:6: SSL Handshake failed for TCP y.y.y.y:63127 → z.z.z.z:443 Nov 12 03:18:53 dc1lbc2p warning tmm[11446]: 01260009:4: Connection error: ssl_hs_rxhello:7103: unsupported version (40)
Did ssldump and ssl debugs but can’t figure it out. There are no low encryption ciphers being presented by clients. In fact I don’t see any handshake errors in the packet captures. Its pretty baffling. Would be great if someone can throw some light. Techs at F5 haven’t been able to figure it out either.
Thanks Naresh
Have you checked this one out?
Yes I have, this did not help. Sorry.
I think this issue is the following.
I recommend your bigip should be upgraded.
Upgraded to what? I am already running TMOS 12.0.
Naresh, it looks like you’ve been working in two threads: DevCentral
You indicated in the other thread that the server sends a reset AFTER the client sends an application data packet, and here you said that you don’t see any handshake failures at all. That could indicate just a few things:
  1. I know you’re convinced that this is a client side issue, but you might actually see this pattern on the client side if the server side SSL was broken. Have you done SSL captures on the server side?
  2. If both sides are handling SSL just fine, then the likely issue is inside the layer 7 communications. You may need to force an RSA key exchange and crack open the SSL traffic with ssldump and the -k option to see what that looks like.
Kevin,
Yes sorry. I got an email from Devcentral and the link in that landed me on the other thread that I didn’t know existed and it had same title. Later I realized my mistake but anyway thanks for your response.
  1. I have no serverside ssl enabled, ssl terminates at the F5.
  2. I did ssldump with -k option with key but I can’t see what is going on inside application_data, which I was hoping to see. Also tried -A but can’t see any details.
Naresh
I meant SSL terminates at VIP (not fully awake yet I guess).
Okay, I guess I assumed from the other thread that you were doing SSL on the server side. So this actually makes things a bit easier. Let’s try some additional tests:
  1. Run an tcpdump, listening ONLY on the server side VLAN. Do you see ANY traffic going to the server when you test? If you do, do you see a reset coming from the server?
  2. With the -k option you also need to:
    a. Provide the private key (the one you use in the client SSL profile)
    ssldump -k /path/to/private.key -AdNn -i [client-side VLAN] port 443 [and any additional filters]
    b. Force the client and BIG-IP to use an RSA key exchange. The simplest option here might be to just temporarily change the Cipher string in the client SSL profile to: !SSLv3:RSA+AES. This will allow ssldump to decrypt the traffic.
  3. Run a client side capture like HTTPWatch or Fiddler and see if there’s any HTTP traffic before it fails, and if so where it fails.
You actually have a few clients in this capture, so I’ll strip out everything but the last one (569) and re-format for visibility:
New TCP connection 569: 70.198.140.97(7336) <-> x.x.x.x(443)
569 1 0.1171 (0.1171) C>SV3.3(184) Handshake
    ClientHello
        Version 3.3
        random[32]= 56 4a c5 04 f4 09 eb...
        cipher suites
            TLS_EMPTY_RENEGOTIATION_INFO_SCSV
            TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384
            TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256
            TLS_ECDHE_ECDSA_WITH_RC4_128_SHA
            TLS_ECDHE_ECDSA_WITH_3DES_EDE_CBC_SHA
            TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
            TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
            TLS_ECDHE_RSA_WITH_RC4_128_SHA
            TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA
            TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384
            TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256
            TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384
            TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256
            TLS_ECDH_ECDSA_WITH_RC4_128_SHA
            TLS_ECDH_ECDSA_WITH_3DES_EDE_CBC_SHA
            TLS_ECDH_RSA_WITH_RC4_128_SHA
            TLS_ECDH_RSA_WITH_3DES_EDE_CBC_SHA
            TLS_RSA_WITH_AES_256_CBC_SHA256
            TLS_RSA_WITH_AES_128_CBC_SHA256
            TLS_RSA_WITH_RC4_128_SHA
            TLS_RSA_WITH_RC4_128_MD5
            TLS_RSA_WITH_3DES_EDE_CBC_SHA
            TLS_DHE_RSA_WITH_AES_128_CBC_SHA256
            TLS_DHE_RSA_WITH_AES_256_CBC_SHA256
            TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA
            compression methods
                NULL
The client is issuing its request to start an SSL session. The ClientHello message contains the client’s preferred protocol (Version 3.3 = TLSv1.2), a random number, and a list of supported cipher suites (in general order of preference)
569 2 0.1180 (0.0009) S>CV3.3(85) Handshake
ServerHello
        Version 3.3
        random[32]= 6c 0f a3 fc 6e d1 8a...
        session_id[32]= e8 27 5b f0 9c 4a...
        cipherSuite
            compressionMethod
                NULL
The server responds with a ServerHello that contains the selected protocol (Version 3.3), its own random number, and the selected cipher from the client’s list (TLS_DHE_RSA_WITH_AES_256_CBC_SHA256)
569 3 0.1180 (0.0000) S>CV3.3(2488) Handshake
    Certificate
        Subject
            C=US
            ST=California L=Mountain View
            O=abc, Inc.
            OU=Network Operations
            CN=*.abc.net Issuer
            C=US O=thawte, Inc.
            CN=thawte SHA256 SSL CA
        Serial      49 a1 db 0d 32 5e a5 16 dd 0b 5c 71 eb ec f3 6a
        Extensions
            Extension:
                X509v3 Subject Alternative Name Extension:
                X509v3 Basic Constraints Extension:
                X509v3 Certificate Policies Extension:
                X509v3 Key Usage Critical Extension:
                X509v3 Authority Key Identifier Extension:
                X509v3 CRL Distribution Points Extension:
                X509v3 Extended Key Usage Extension:
                Authority Information Access
        Subject
            C=US O=thawte, Inc.
        Issuer
            C=US O=thawte, Inc.
            OU=Certification Services Division
            OU=(c) 2008 thawte, Inc. - For authorized use only
            CN=thawte Primary Root CA - G3
        Serial      36 34 9e 18 c9 9c 26 69 b6 56 2e 6c e5 ad 71 32
        Extensions
            Extension:
                Authority Information Access Extension:
                X509v3 Basic Constraints Critical Extension:
                X509v3 Subject Key Identifier Extension:
The server immediately sends a Certificate message that should contain its own certificate and optionally any immediate issuing CAs.
569 4 0.1180 (0.0000) S>CV3.3(527) Handshake
    ServerKeyExchange
        params
            DH_p[128]= b9 77 c2 e3 f9 1d 78 15...
            DH_g[1]= 02
            DH_Ys[128]= 58 5d 21 35 30 dc 7f 35...
The server follows the Certificate message with a ServerKeyExchange message, which generally only occurs when a Diffie-Hellman cipher is selected. Here the server is sending its DH parameters.
569 5 0.1180 (0.0000) S>CV3.3(4) Handshake
    ServerHelloDone
The server then indicates it’s done with a ServerHelloDone message.
569 0.6487 (0.5306) C>S TCP FIN
569 0.6487 (0.0000) S>C TCP FIN
What should be next is the client’s ClientKeyExchange message, which for Diffie-Hellman is the client’s DH parameters (or for RSA the encrypted pre-master secret). As the client is sending a FIN at this point, the most likely cause is that the client doesn’t like something about the server’s response. We can pretty much rule out cipher selection and protocol, as those were selected from the client’s list. You may have scrubbed the data a little too much here, but one interesting thing I noticed is that the server’s certificate chain starts with a CA (CN=thawte SHA256 SSL CA). Is that correct? At this point in the SSL handshake the client is going to attempt to validate the server’s certificate. If the client cannot establish a trust chain with the server’s certificate, or the server’s certificate is otherwise invalid, the client agent may either prompt the user with an “untrusted certificate” warning, or in some circumstances just fail completely. My guess here, assuming the capture is mostly intact, is that the client is failing the SSL handshake because of the certificates presented. If you test access to the BIG-IP VIP with cURL,
curl -k https://x.x.x.x
(the -k tells cURL to ignore certificate trust issues) do you get any further?
Kevin,
Thanks for looking at it, sorry for the bad formatting. Yes “thawte SHA256 SSL CA” is fine. The clientssl profile that I use here is used in 100s of more VIPs and have no problem with certificate chain. I have tried to use the one with a bad chain and I get a different error - something to the effect “unknown_ca” in packet capture, which I am not seeing here. Since Handshake failed, no application_data started. I am still at a loss to understand why this (and others I sent) failed. One of them only has one line where client makes a new connection to server and fails right after, making no sense of what happened.
Naresh
Yes, but is “thawte SHA256 SSL CA” an actual CA certificate? Is that the server cert and key you have defined in the client SSL profile? Is it failing with all browsers? Have you tried the cURL client? Did you enable HSTS in v12?
Yes it is an actual certificate that I have defined in SSL profile. Not sure what you mean by failing with all browsers. The web sites are mostly working but for these frequent SSL handshake errors from some clients. Curl shows the html from web site - as expected. No new information there.
* STATE: INIT => CONNECT handle 0x6000572f0; line 1090 (connection -5000)
* Rebuilt URL to: https://abc.net
* Added connection 0. The cache now contains 1 members
*   Trying 63.128.130.61...
* STATE: CONNECT => WAITCONNECT handle 0x6000572f0; line 1143 (connection 0)
* Connected to abc.net (63.128.130.61) port 443 (0)
* STATE: WAITCONNECT => SENDPROTOCONNECT handle 0x6000572f0; line 1240 (connection 0)
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
*   CAfile: /etc/pki/tls/certs/ca-bundle.crt
  CApath: none
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* STATE: SENDPROTOCONNECT => PROTOCONNECT handle 0x6000572f0; line 1254 (connection 0)
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
* ALPN, server did not agree to a protocol
* Server certificate:
*        subject: C=US; ST=California; L=Mountain View; O=ABC, Inc.; OU=Network Operations; CN=*.abc.net
*        start date: Apr  9 00:00:00 2015 GMT
*        expire date: Apr  3 23:59:59 2016 GMT
*        issuer: C=US; O=thawte, Inc.; CN=thawte SHA256 SSL CA
*        SSL certificate verify ok.
* STATE: PROTOCONNECT => DO handle 0x6000572f0; line 1275 (connection 0)
> GET / HTTP/1.1
> Host: abc.net
> User-Agent: curl/7.45.0
> Accept: */*
* STATE: DO => DO_DONE handle 0x6000572f0; line 1337 (connection 0)
* STATE: DO_DONE => WAITPERFORM handle 0x6000572f0; line 1464 (connection 0)
* STATE: WAITPERFORM => PERFORM handle 0x6000572f0; line 1474 (connection 0)
* HTTP 1.1 or later with persistent connection, pipelining supported
< HTTP/1.1 403 Forbidden
< Date: Tue, 17 Nov 2015 15:41:39 GMT
* Server Apache is not blacklisted
< Server: Apache
< Last-Modified: Wed, 23 Apr 2014 23:57:35 GMT
< Accept-Ranges: bytes
< Content-Length: 1212
< Strict-Transport-Security: max-age=500
< X-XSS-Protection: 1
< Cache-Control: max-age=0, no-store
< Content-Type: text/html
I wasn't aware of HSTS but headers show:
Does it mean its enabled and causing the issue? What does it do and can I disable it if this is the root cause?
Naresh
Yes, this header indicates that you’re using HSTS. Basically, that header tells the browser a few things:
  1. For all subsequent requests to this URL, always connect via HTTPS (regardless of the URLs presented to the browser)
  2. If for any reason the server’s certificate cannot be validated, fail completely. In other words you don’t get the option to bypass/ignore the error. It just fails.
It’s very likely working in cURL because cURL doesn’t understand HSTS. The max-age directive is in seconds, and that’s how long the browser caches this information. Thankfully you didn’t specify the usual 1 week, because it’s very difficult to clear that cache. So at the very least you need to uncheck this value in the HTTP profile and wait 500 seconds to allow the browser to forget the setting. You may notice afterwards that the browser will prompt you to ignore the untrusted cert.
Kevin,
I should see this in my bigip.conf profile:
hsts {
        mode enabled
but I am not seeing it there. Search for hsts in bigip.conf didn’t find anything. Not sure what this means.
Naresh
If this is v12 you should definitely see an hsts setting in HTTP profile. In either case, in the HTTP profile assigned to this VIP, do you see the HTTP Strict Transport Security option (at the botton of the profile)? And if so is it enabled? If it’s not enabled, is it possible that the application itself is sending the HSTS header?
I don’t see it
[root@xxx:Active:In Sync] config grep hsts bigip.conf [root@xxx:Active:In Sync] config
Not sure about clients being able to do that and cause handshake errors?
Look at the HTTP profile in the GUI. This is v12?
The point is that a modern browser will fail on trust issues if this header is present.
Hit send too soon. This isn’t enabled by default in a v12 HTTP profile, so do you have an iRule sending it? Can you tell if the application server is configured to send it?
No its not configured in an iRule and No clients are not configured to send it.
