Not clients. Servers. If you’re seeing this header at the client, then someone is sending it.
From header it seems like server is sending it but I haven’t configured it on bigip.
< Strict-Transport-Security: max-age=500
Great, so first step is to turn it off at the server. If you can’t do that, try this simple iRule to remove it from responses:
when HTTP_RESPONSE {
if { [HTTP::header exists "Strict-Transport-Security" } {
HTTP::header remove "Strict-Transport-Security"
If that does the trick, then you just need to wait that 500 seconds for the cache to timeout and then try again.
I should mention now, for the sake of completeness, that it’s a security best practice to leave that header enabled. Once you’ve solved the trust issues without the header, you’ll want to turn it back on.
Ok. I disabled hsts and waited for 500 seconds and more, still got SSL handshake errors. Following are 2 examples when hsts was removed. Notice the “critical” in the middle of handshake and abrupt FINs sent by client and server.
New TCP connection 31: 70.114.201.226(55098) <-> x.x.x.x(443)
30 6 0.2040 (0.1128) C>SV3.3(70) Handshake
ClientKeyExchange
30 7 0.2040 (0.0000) C>SV3.3(1) ChangeCipherSpec
30 8 0.2040 (0.0000) C>SV3.3(64) Handshake
30 9 0.2053 (0.0013) S>CV3.3(1) ChangeCipherSpec
30 10 0.2053 (0.0000) S>CV3.3(64) Handshake
31 1 0.1392 (0.1392) C>SV3.3(184) Handshake
ClientHello
Version 3.3
random[32]=
56 4c 20 92 37 cd ef 90 aa 66 36 f3 aa 9f be 9e
d2 96 ac d6 6f 3f ee 4e 39 a6 d2 75 a3 c3 f5 82
cipher suites
TLS_EMPTY_RENEGOTIATION_INFO_SCSV
TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384
TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256
TLS_ECDHE_ECDSA_WITH_RC4_128_SHA
TLS_ECDHE_ECDSA_WITH_3DES_EDE_CBC_SHA
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
TLS_ECDHE_RSA_WITH_RC4_128_SHA
TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA
TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384
TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256
TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384
TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256
TLS_ECDH_ECDSA_WITH_RC4_128_SHA
TLS_ECDH_ECDSA_WITH_3DES_EDE_CBC_SHA
TLS_ECDH_RSA_WITH_RC4_128_SHA
TLS_ECDH_RSA_WITH_3DES_EDE_CBC_SHA
TLS_RSA_WITH_AES_256_CBC_SHA256
TLS_RSA_WITH_AES_128_CBC_SHA256
TLS_RSA_WITH_RC4_128_SHA
TLS_RSA_WITH_RC4_128_MD5
TLS_RSA_WITH_3DES_EDE_CBC_SHA
TLS_DHE_RSA_WITH_AES_128_CBC_SHA256
TLS_DHE_RSA_WITH_AES_256_CBC_SHA256
TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA
compression methods
NULL
31 2 0.1403 (0.0010) S>CV3.3(91) Handshake
ServerHello
Version 3.3
random[32]=
67 f0 29 68 55 5a a3 e9 5d 9d 2d 11 4b fe 44 7d
ba a8 3c c9 23 48 60 d7 63 ad b6 61 1e 53 c3 c9
session_id[32]=
c6 6c e9 26 5b f1 9d 4a 2f b5 ba 33 42 b9 c4 53
c4 0a 4f 40 29 f2 9b 2c 65 6b ac e9 12 49 14 63
cipherSuite TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
compressionMethod NULL
31 3 0.1403 (0.0000) S>CV3.3(2488) Handshake
Certificate
Subject
C=US
ST=California
L=Mountain View
O=abc, Inc.
OU=Network Operations
CN=*.abc.net
Issuer
C=US
O=thawte, Inc.
CN=thawte SHA256 SSL CA
Serial 49 a1 db 0d 32 5e a5 16 dd 0b 5c 71 eb ec f3 6a
Extensions
Extension: X509v3 Subject Alternative Name
Extension: X509v3 Basic Constraints
Extension: X509v3 Certificate Policies
Extension: X509v3 Key Usage
Critical
Extension: X509v3 Authority Key Identifier
Extension: X509v3 CRL Distribution Points
Extension: X509v3 Extended Key Usage
Extension: Authority Information Access
Subject
C=US
O=thawte, Inc.
Issuer
C=US
O=thawte, Inc.
OU=Certification Services Division
OU=(c) 2008 thawte, Inc. - For authorized use only
CN=thawte Primary Root CA - G3
Serial 36 34 9e 18 c9 9c 26 69 b6 56 2e 6c e5 ad 71 32
Extensions
Critical
Critical
Extension: X509v3 Subject Key Identifier
31 4 0.1404 (0.0000) S>CV3.3(333) Handshake
ServerKeyExchange
31 5 0.1404 (0.0000) S>CV3.3(4) Handshake
ServerHelloDone
30 11 0.3403 (0.1350) C>SV3.3(544) application_data
30 12 0.3436 (0.0032) S>CV3.3(1456) application_data
30 13 0.3436 (0.0000) S>CV3.3(1488) application_data
30 14 0.3436 (0.0000) S>CV3.3(1488) application_data
30 15 0.3436 (0.0000) S>CV3.3(144) application_data
30 16 0.3441 (0.0004) S>CV3.3(1488) application_data
30 17 0.4304 (0.0862) S>CV3.3(1488) application_data
30 18 0.4304 (0.0000) S>CV3.3(1488) application_data
30 19 0.4304 (0.0000) S>CV3.3(1488) application_data
30 20 0.4304 (0.0000) S>CV3.3(1488) application_data
30 21 0.4304 (0.0000) S>CV3.3(1488) application_data
30 22 0.4304 (0.0000) S>CV3.3(1040) application_data
31 0.7382 (0.5978) C>S TCP FIN
31 0.7383 (0.0000) S>C TCP FIN
13 11 9.1953 (9.1702) C>SV3.3(448) application_data
13 12 9.1978 (0.0024) S>CV3.3(1472) application_data
13 13 9.1978 (0.0000) S>CV3.3(1520) application_data
13 14 9.1978 (0.0000) S>CV3.3(1520) application_data
13 15 9.1978 (0.0000) S>CV3.3(176) application_data
13 16 9.1980 (0.0001) S>CV3.3(1520) application_data
13 17 9.1980 (0.0000) S>CV3.3(1520) application_data
13 18 9.1981 (0.0001) S>CV3.3(1520) application_data
13 19 9.1981 (0.0000) S>CV3.3(1520) application_data
13 20 9.1982 (0.0001) S>CV3.3(1520) application_data
13 21 9.2086 (0.0103) S>CV3.3(1520) application_data
13 22 9.2098 (0.0011) S>CV3.3(1328) application_data
New TCP connection 254: 81.169.237.146(49648) <-> x.x.x.x(443)
254 1 0.1686 (0.1686) C>SV3.1(160) Handshake
ClientHello
Version 3.1
random[32]=
4f e0 34 c6 b9 14 78 a8 d4 5c c8 bd 85 9c 4a 75
03 aa b4 69 4d e4 8a 1f ff 64 0b 25 e9 07 33 dd
cipher suites
TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
compression methods
NULL
254 2 0.1697 (0.0010) S>CV3.1(87) Handshake
ServerHello
Version 3.1
random[32]=
42 31 2f 60 10 8f 42 75 ab ed 8a d9 03 32 16 7e
b5 6e 06 64 62 9c 1e ec d5 fd 40 58 49 73 18 eb
session_id[32]=
c3 46 ec 69 a6 db 70 1d cb ae a2 bc 2f c2 39 44
6c 11 05 cf b4 d9 76 1b 2a 50 89 36 3f 92 c9 94
254 3 0.1697 (0.0000) S>CV3.1(2488) Handshake
Certificate
Subject
C=US
ST=California
L=Mountain View
O=abc, Inc.
CN=*.abc.net
Issuer
C=US
O=thawte, Inc.
Extensions
Critical
Subject
C=US
O=thawte, Inc.
Issuer
C=US
O=thawte, Inc.
Extensions
Critical
Critical
254 4 0.1697 (0.0000) S>CV3.1(331) Handshake
ServerKeyExchange
254 5 0.1697 (0.0000) S>CV3.1(4) Handshake
ServerHelloDone
69 64.4153 (59.9118) S>C TCP FIN
69 64.4152 C>S TCP FIN
225 11 10.0037 (9.8402) C>SV3.1(752) application_data
225 12 10.0063 (0.0025) S>CV3.1(480) application_data
254 0.3390 (0.1692) C>S TCP FIN
254 0.3391 (0.0000) S>C TCP FIN
A couple of things to note:
You still have a few different client connections going on here. You can tell by the first number on each line (ex. 30, 31, 13, 254). I’ll focus on 31 and 254 as they’re the most complete captures.
The “Critical” you’re seeing is an X.509 extension property. In most cases a client or server in receipt of a peer’s certificate can ignore X.509 extensions that it doesn’t understand, except in the case of critical extensions. It’s quite common for the Key Usage and Basic Constraints extensions to be marked Critical.
Tcpdump and ssldump can sometimes display packets out of order. In this case though, the very next message should be a ClientKeyExchange from the client, so we can be pretty sure here that the client is the one with the issue.
I’m not definitively saying that HSTS is the issue here, but in a real-world scenario HSTS will prevent access if the browser can’t trust the presented certificate. Because we know the HSTS header is/was present, it’s a “low hanging fruit” so to speak. Have you tried this with a few different browsers (ie. Internet Explorer, Chrome, FireFox, etc.)? If it doesn’t work in Chrome or Opera, go to chrome://net-internals/hsts and query for the domain there to see if it’s in the list. If it isn’t, then HSTS isn’t the problem.
In any case, it appears from everything I’ve observed so far that the client is indeed the problem. If a cURL client (ignoring certificate trust) can access the site, but a browser can’t, it almost certainly has something to do with certificate trust. Can you test with a new client SSL profile? Or better, the default clientssl profile (assuming HSTS isn’t involved).
I get “Not found” in chrome. I was never able to reproduce a not available site in any of the browsers. I have only seen SSL handshake errors in logs.
A “Not Found” as in a 404 response? A 404 is an application layer error, which implies a successful SSL handshake. Can you do a client side capture (HTTPWatch, Fiddler, etc.) and look for exactly what the client is asking for and if any of those requests are getting answered. It may be that some of the resource requests are failing, but not all.
Do you get the same error in all browsers?
Not found literally with “chrome://net-internals/hsts”. Not a 404 error. I wasn’t able to reproduce a connection failure with any of the browsers while going to the web site. I just see handshake errors.
Okay, so if you’re not having any issues getting to the application via browsers, I’d simply run a client side capture to see if any elements of that application are failing. It doesn’t really make any sense that the SSL handshakes you’re looking at are failing where they are, but that you’re still able to get to the application. Something’s missing in this equation.
Kevin,
Failures are coming from random clients over the Internet. I haven’t been able to reproduce and so my captures won’t show the error. I’m not sure if there is a way to create it.
Naresh
Kevin,
I reproduced this error on renegotiation. Could this be the cause for all those handshake errors:
openssl s_client -connect x.x.x.x:443
CONNECTED(00000003)
depth=2 C = US, O = "thawte, Inc.", OU = Certification Services Division, OU = "(c) 2008 thawte, Inc. - For authorized use only", CN = thawte Primary Root CA - G3
verify return:1
depth=1 C = US, O = "thawte, Inc.", CN = thawte SHA256 SSL CA
verify return:1
Removed bunch of stuff here
SSL handshake has read 2983 bytes and written 442 bytes
New, TLSv1/SSLv3, Cipher is ECDHE-RSA-AES256-GCM-SHA384
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : ECDHE-RSA-AES256-GCM-SHA384
Session-ID: 82F80492D73C79776AC0FCEE3C8520FF237E79DB979BCBFFB62633FD0E15700F
Session-ID-ctx:
Master-Key: D36B850714E6F95E22DA3653F9410D7F10F8DE29A1BD889602DA27D28006D9258895C0777B361BAF6AE506B983CCF9F9
Key-Arg : None
PSK identity: None
PSK identity hint: None
SRP username: None
Start Time: 1448044924
Timeout : 300 (sec)
Verify return code: 0 (ok)
R
RENEGOTIATING
2283136:error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure:s3_pkt.c:1472:SSL alert number 40
2283136:error:1409E0E5:SSL routines:ssl3_write_bytes:ssl handshake failure:s3_pkt.c:656:
What do you think?
Nevermind, LTM logs throw a different error here.
Nov 20 10:46:46 dc1lbc2s warning tmm[8569]: 01260009:4: Connection error: ssl_hs_rxhello:6822: renegotiation disallowed (40)
Kevin,
What went wrong here -
363 1 1448048245.1572 (0.0026) C>SV3.2(163) Handshake
ClientHello
Version 3.2
random[32]=
56 4f 76 75 17 79 bb e4 bb 1d 18 6d 65 65 f7 14
60 a5 de 1b 2c dc 2a d7 3d ee 8c d0 0e a4 83 e1
cipher suites
TLS_DHE_DSS_WITH_AES_256_CBC_SHA
TLS_DHE_DSS_WITH_AES_128_CBC_SHA
TLS_DHE_DSS_WITH_3DES_EDE_CBC_SHA
compression methods
NULL
363 2 1448048245.1584 (0.0011) S>CV3.2(87) Handshake
ServerHello
Version 3.2
random[32]=
52 c7 9d f6 0f e8 9e c4 39 2d 8e 51 49 ef b4 12
8a 3a 68 15 fe 7b a9 5c a7 de f9 e0 46 27 b0 20
session_id[32]=
1a b0 5c 0b ee 75 50 6f 02 78 ec a2 57 bd f8 f7
e3 72 9d 63 8f 53 a3 07 57 8d 9b 75 26 4d 48 07
363 3 1448048245.1584 (0.0000) S>CV3.2(2488) Handshake
Certificate
Subject
C=US
ST=California
L=Mountain View
O=abc, Inc.
CN=*.abc.net
Issuer
C=US
O=thawte, Inc.
Extensions
Critical
Subject
C=US
O=thawte, Inc.
Issuer
C=US
O=thawte, Inc.
Extensions
Critical
Critical
363 4 1448048245.1584 (0.0000) S>CV3.2(331) Handshake
ServerKeyExchange
363 5 1448048245.1584 (0.0000) S>CV3.2(4) Handshake
ServerHelloDone
363 6 1448048245.1624 (0.0039) C>SV3.2(70) Handshake
ClientKeyExchange
363 7 1448048245.1641 (0.0017) C>SV3.2(1) ChangeCipherSpec
363 8 1448048245.1642 (0.0000) C>SV3.2(64) Handshake
363 9 1448048245.1644 (0.0001) S>CV3.2(2) Alert
level fatal
value bad_record_mac
363 1448048245.1644 (0.0000) S>C TCP FIN
363 1448048245.1651 (0.0007) C>S TCP FIN
The first encrypted message sent by either party is the Finished message, seen here as the “Handshake” message at 363 8. The alert essentially means that the server (F5) was unable to decrypt this message and/or verify its mac (ie. signature). Unfortunately there’s a few different reasons for this event to occur, including a bad client or server crypto implementation, bad server public or private key, and potentially any network issues that could have corrupted some part of the previous handshake.
Have you been able to isolate and reproduce this error?
Kevin,
This is not coming from a browser, its coming from a Java client. Not sure how to reproduce this, happens at random every few minutes.
Hard to troubleshoot that sort of thing. Does the Java client log anything extra? Does it store the server’s public key anywhere? Is it that this same Java client randomly fails across multiple tests, or fails every time?
I’ll check if java client logs anything and if servers public key is cached (even if its cached, it doesn’t change, should that matter?). There are multiple java clients failing randomly against 2 VIPs that they connect for ldap auth.
This one I can understand why it failed.
488 1 1448055944.6885 (0.0545) C>SV3.0(53) Handshake
ClientHello
Version 3.0
random[32]=
56 4f 94 87 6d 31 8e 91 b2 11 64 76 c0 89 64 73
7b eb 38 af 52 e8 83 22 6b 9a 9e 00 63 19 fb db
cipher suites
SSL_RSA_WITH_3DES_EDE_CBC_SHA
SSL_DHE_DSS_WITH_3DES_EDE_CBC_SHA
SSL_RSA_WITH_RC4_128_SHA
SSL_RSA_WITH_RC4_128_MD5
SSL_EMPTY_RENEGOTIATION_INFO_SCSV
compression methods
NULL
488 2 1448055944.6887 (0.0001) S>CV3.0(2) Alert
level fatal
value handshake_failure
488 1448055944.6887 (0.0000) S>C TCP FIN
Here is another commonly failing handshake:
Captured 3 different streams from 3 clients, fails right after ServerHelloDone. Client sends finish, not sure why.
154 1 1448055928.8001 (0.1000) C>SV3.1(175) Handshake
154 2 1448055928.8013 (0.0011) S>CV3.3(91) Handshake
154 3 1448055928.8013 (0.0000) S>CV3.3(2488) Handshake
154 4 1448055928.8013 (0.0000) S>CV3.3(365) Handshake
154 5 1448055928.8013 (0.0000) S>CV3.3(4) Handshake
ServerHelloDone
154 1448055928.9049 (0.1035) C>S TCP FIN
154 1448055928.9049 (0.0000) S>C TCP FIN
406 1 1448055941.9187 (0.2517) C>SV3.1(114) Handshake
406 2 1448055941.9196 (0.0009) S>CV3.1(80) Handshake
406 3 1448055941.9196 (0.0000) S>CV3.1(2488) Handshake
406 4 1448055941.9196 (0.0000) S>CV3.1(525) Handshake
406 5 1448055941.9196 (0.0000) S>CV3.1(4) Handshake
ServerHelloDone
406 1448055942.2304 (0.3107) C>S TCP FIN
406 1448055942.2306 (0.0001) S>C TCP FIN
604 1 1448055950.8339 (1.0157) C>SV3.1(233) Handshake
604 2 1448055950.8351 (0.0012) S>CV3.3(91) Handshake
604 3 1448055950.8351 (0.0000) S>CV3.3(2488) Handshake
604 4 1448055950.8351 (0.0000) S>CV3.3(333) Handshake
604 5 1448055950.8351 (0.0000) S>CV3.3(4) Handshake
ServerHelloDone
604 1448055951.8045 (0.9693) C>S TCP FIN
604 1448055951.8046 (0.0001) S>C TCP FIN
