SSL Cipher Order on LTM
Hi All -
With this whole POODLE thing, I’m reevaluating my cipher string. I am considering going with the DEFAULT setting that F5 provides (11.5.1), but I notice that it has the forward secrecy ciphers towards the end of the list. Can anyone explain why the forward secrecy ciphers would be less preferred over the RSA ciphers? Any reason I should just go with DEFAULT as opposed to customizing my cipher list?
For reference, 11.5.1’s DEFAULT is:
!SSLv2:!SSLv3:!MD5:!EXPORT:RSA+AES:RSA+3DES:RSA+RC4:ECDHE+AES:ECDHE+3DES:ECDHE+RC4
I’m considering using the same ciphers, just changing the order:
!SSLv2:!SSLv3:!MD5:!EXPORT:ECDHE+AES:ECDHE+3DES:ECDHE+RC4:RSA+AES:RSA+3DES:RSA+RC4
Thoughts?
Thanks,
Al
I can’t say the reason for the default order, though it has seemed in the past F5 has preferred speed over encryption strength. I have switched to using my own lists on sites that I need the highest security on.
Also, I would drop RC4 completely. See 404 Page not found | BIG-IP Documentation Even if you upgrade to 11.6 to mitigate this attack, most people tend to consider it broken and not advisable to use.
