How to disable RC4 Cipher on SSL
Hi team,
Can you help us to disable RC4 Cipher on SSL. Big-IP Version 11.5
Thanks!
Goldz
For example, You can configure the following cipher in your ssl profile :
DEFAULT:!RC4
Hope it helps.
root@(bigip1)(cfg-sync Standalone)(Active)(/Common)(tmos.ltm) create profile client-ssl No-RC4-clientssl defaults-from clientssl ciphers DEFAULT:!RC4
root@(bigip1)(cfg-sync Standalone)(Active)(/Common)(tmos.ltm) list profile client-ssl No-RC4-clientssl
ltm profile client-ssl No-RC4-clientssl {
    app-service none
    cert default.crt
    cert-key-chain {
        default {
            cert default.crt
            key default.key
    chain none
    inherit-certkeychain true
    key default.key
    passphrase none
I have RC4 disabled but am still getting a grade of B running against qualys SSL server test: This server accepts RC4 cipher, but only with older clients. Grade capped to B.
SSL profile setting = DEFAULT:!SSLv3:!TLSv1:!RC4:@STRENGTH
Any feedback?
Hi @jaikumar_f5
Is there any impact if we are going to disable RC4 cipher, please your input is valuable
RC4 was recommended to be disabled many years back. Guess in 2015 due to many vulnerabilities and AES alone is encouraged. RC4 is a considered insecure for modern app and many organizations by default have RC4 disabled.
So in short, unless you have a very old legacy application which relies on RC4, one doesn’t have to worry.
Hi   @jaikumar_f5  can you please
One more query how can verify we are not disabled RC4 in the ciphers list..
following is the output of our appliances
list /sys httpd ssl-ciphersuite sys httpd { ssl-sslciphersuite "ALL" }
ltm cipher group IS-recommend-Cipher { allow { ECDHE-RSA-CHACHA20-POLY1305-SHA256 { } ECDHE-RSA-AES256-GCM-SHA384 { } ECDHE-RSA-AES128-GCM-SHA256 { } ECDHE-ECDSA-CHACHA20-POLY1305-SHA256 { } ECDHE-ECDSA-AES256-GCM-SHA384 { } ECDHE-ECDSA-AES128-GCM-SHA256 { } DHE-RSA-AES256-GCM-SHA384 { } DHE-RSA-AES128-GCM-SHA256 { }
show /ltm cipher rule
Ltm::Cipher::Rule
Name                        Result
f5-aes                      ECDHE-RSA-AES128-GCM-SHA256/TLS1.2:ECDHE-RSA-AES256-GCM-SHA384/TLS1.2:ECDH-RSA-AES128-GCM-SHA256/TLS1.2:ECDH-RSA-AES256-GCM-SHA384/TLS1.2:AES128-GCM-SHA256/TLS1.2:AES256-GCM-SHA384/TLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256/TLS1.2:ECDHE-ECDSA-AES256-GCM-SHA384/TLS1.2:ECDH-ECDSA-AES128-GCM-SHA256/TLS1.2:ECDH-ECDSA-AES256-GCM-SHA384/TLS1.2:DHE-RSA-AES128-GCM-SHA256/TLS1.2:DHE-RSA-AES256-GCM-SHA384/TLS1.2:DHE-DSS-AES128-GCM-SHA256/TLS1.2:DHE-DSS-AES256-GCM-SHA384/TLS1.2:ADH-AES128-GCM-SHA256/TLS1.2:ADH-AES256-GCM-SHA384/TLS1.2:TLS13-AES128-GCM-SHA256/TLS1.3:TLS13-AES256-GCM-SHA384/TLS1.3:ECDHE-RSA-AES128-CBC-SHA/TLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.1:ECDHE-RSA-AES128-CBC-SHA/DTLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.2:ECDHE-RSA-AES128-SHA256/TLS1.2:ECDHE-RSA-AES256-CBC-SHA/TLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.1:ECDHE-RSA-AES256-CBC-SHA/DTLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.2:ECDHE-RSA-AES256-SHA384/TLS1.2:ECDH-RSA-AES128-SHA256/TLS1.2:ECDH-RSA-AES128-SHA/TLS1.0:ECDH-RSA-AES128-SHA/TLS1.1:ECDH-RSA-AES128-SHA/TLS1.2:ECDH-RSA-AES256-SHA384/TLS1.2:ECDH-RSA-AES256-SHA/TLS1.0:ECDH-RSA-AES256-SHA/TLS1.1:ECDH-RSA-AES256-SHA/TLS1.2:AES128-SHA/SSLv3:AES128-SHA/TLS1.0:AES128-SHA/TLS1.1:AES128-SHA/TLS1.2:AES128-SHA/DTLS1.0:AES128-SHA256/TLS1.2:AES256-SHA/SSLv3:AES256-SHA/TLS1.0:AES256-SHA/TLS1.1:AES256-SHA/TLS1.2:AES256-SHA/DTLS1.0:AES256-SHA256/TLS1.2:ECDHE-ECDSA-AES128-SHA/TLS1.0:ECDHE-ECDSA-AES128-SHA/TLS1.1:ECDHE-ECDSA-AES128-SHA/TLS1.2:ECDHE-ECDSA-AES128-SHA256/TLS1.2:ECDHE-ECDSA-AES256-SHA/TLS1.0:ECDHE-ECDSA-AES256-SHA/TLS1.1:ECDHE-ECDSA-AES256-SHA/TLS1.2:ECDHE-ECDSA-AES256-SHA384/TLS1.2:ECDH-ECDSA-AES128-SHA/TLS1.0:ECDH-ECDSA-AES128-SHA/TLS1.1:ECDH-ECDSA-AES128-SHA/TLS1.2:ECDH-ECDSA-AES128-SHA256/TLS1.2:ECDH-ECDSA-AES256-SHA/TLS1.0:ECDH-ECDSA-AES256-SHA/TLS1.1:ECDH-ECDSA-AES256-SHA/TLS1.2:ECDH-ECDSA-AES256-SHA384/TLS1.2:DHE-RSA-AES128-SHA/SSLv3:DHE-RSA-AES128-SHA/TLS1.0:DHE-RSA-AES128-SHA/TLS1.1:DHE-RSA-AES128-SHA/TLS1.2:DHE-RSA-AES128-SHA/DTLS1.0:DHE-RSA-AES128-SHA256/TLS1.2:DHE-RSA-AES256-SHA/SSLv3:DHE-RSA-AES256-SHA/TLS1.0:DHE-RSA-AES256-SHA/TLS1.1:DHE-RSA-AES256-SHA/TLS1.2:DHE-RSA-AES256-SHA/DTLS1.0:DHE-RSA-AES256-SHA256/TLS1.2:DHE-DSS-AES128-SHA/SSLv3:DHE-DSS-AES128-SHA/TLS1.0:DHE-DSS-AES128-SHA/TLS1.1:DHE-DSS-AES128-SHA/TLS1.2:DHE-DSS-AES128-SHA/DTLS1.0:DHE-DSS-AES128-SHA256/TLS1.2:DHE-DSS-AES256-SHA/SSLv3:DHE-DSS-AES256-SHA/TLS1.0:DHE-DSS-AES256-SHA/TLS1.1:DHE-DSS-AES256-SHA/TLS1.2:DHE-DSS-AES256-SHA/DTLS1.0:DHE-DSS-AES256-SHA256/TLS1.2:ADH-AES128-SHA/SSLv3:ADH-AES128-SHA/TLS1.0:ADH-AES256-SHA/SSLv3:ADH-AES256-SHA/TLS1.0
f5-default                  ECDHE-RSA-AES128-GCM-SHA256/TLS1.2:ECDHE-RSA-AES128-CBC-SHA/TLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.1:ECDHE-RSA-AES128-CBC-SHA/DTLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.2:ECDHE-RSA-AES128-SHA256/TLS1.2:ECDHE-RSA-AES256-GCM-SHA384/TLS1.2:ECDHE-RSA-AES256-CBC-SHA/TLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.1:ECDHE-RSA-AES256-CBC-SHA/DTLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.2:ECDHE-RSA-AES256-SHA384/TLS1.2:AES128-GCM-SHA256/TLS1.2:AES128-SHA/TLS1.0:AES128-SHA/TLS1.1:AES128-SHA/TLS1.2:AES128-SHA/DTLS1.0:AES128-SHA256/TLS1.2:AES256-GCM-SHA384/TLS1.2:AES256-SHA/TLS1.0:AES256-SHA/TLS1.1:AES256-SHA/TLS1.2:AES256-SHA/DTLS1.0:AES256-SHA256/TLS1.2:CAMELLIA128-SHA/TLS1.0:CAMELLIA128-SHA/TLS1.1:CAMELLIA128-SHA/TLS1.2:CAMELLIA256-SHA/TLS1.0:CAMELLIA256-SHA/TLS1.1:CAMELLIA256-SHA/TLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256/TLS1.2:ECDHE-ECDSA-AES128-SHA/TLS1.0:ECDHE-ECDSA-AES128-SHA/TLS1.1:ECDHE-ECDSA-AES128-SHA/TLS1.2:ECDHE-ECDSA-AES128-SHA256/TLS1.2:ECDHE-ECDSA-AES256-GCM-SHA384/TLS1.2:ECDHE-ECDSA-AES256-SHA/TLS1.0:ECDHE-ECDSA-AES256-SHA/TLS1.1:ECDHE-ECDSA-AES256-SHA/TLS1.2:ECDHE-ECDSA-AES256-SHA384/TLS1.2:DHE-RSA-AES128-GCM-SHA256/TLS1.2:DHE-RSA-AES128-SHA/TLS1.0:DHE-RSA-AES128-SHA/TLS1.1:DHE-RSA-AES128-SHA/TLS1.2:DHE-RSA-AES128-SHA/DTLS1.0:DHE-RSA-AES128-SHA256/TLS1.2:DHE-RSA-AES256-GCM-SHA384/TLS1.2:DHE-RSA-AES256-SHA/TLS1.0:DHE-RSA-AES256-SHA/TLS1.1:DHE-RSA-AES256-SHA/TLS1.2:DHE-RSA-AES256-SHA/DTLS1.0:DHE-RSA-AES256-SHA256/TLS1.2:DHE-RSA-CAMELLIA128-SHA/TLS1.0:DHE-RSA-CAMELLIA128-SHA/TLS1.1:DHE-RSA-CAMELLIA128-SHA/TLS1.2:DHE-RSA-CAMELLIA256-SHA/TLS1.0:DHE-RSA-CAMELLIA256-SHA/TLS1.1:DHE-RSA-CAMELLIA256-SHA/TLS1.2:TLS13-AES128-GCM-SHA256/TLS1.3:TLS13-AES256-GCM-SHA384/TLS1.3
f5-ecc                      ECDHE-RSA-AES128-GCM-SHA256/TLS1.2:ECDHE-RSA-AES128-CBC-SHA/TLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.1:ECDHE-RSA-AES128-CBC-SHA/DTLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.2:ECDHE-RSA-AES128-SHA256/TLS1.2:ECDHE-RSA-AES256-GCM-SHA384/TLS1.2:ECDHE-RSA-AES256-CBC-SHA/TLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.1:ECDHE-RSA-AES256-CBC-SHA/DTLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.2:ECDHE-RSA-AES256-SHA384/TLS1.2:ECDHE-RSA-CHACHA20-POLY1305-SHA256/TLS1.2:ECDHE-RSA-DES-CBC3-SHA/TLS1.0:ECDHE-RSA-DES-CBC3-SHA/TLS1.1:ECDHE-RSA-DES-CBC3-SHA/TLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256/TLS1.2:ECDHE-ECDSA-AES128-SHA/TLS1.0:ECDHE-ECDSA-AES128-SHA/TLS1.1:ECDHE-ECDSA-AES128-SHA/TLS1.2:ECDHE-ECDSA-AES128-SHA256/TLS1.2:ECDHE-ECDSA-AES256-GCM-SHA384/TLS1.2:ECDHE-ECDSA-AES256-SHA/TLS1.0:ECDHE-ECDSA-AES256-SHA/TLS1.1:ECDHE-ECDSA-AES256-SHA/TLS1.2:ECDHE-ECDSA-AES256-SHA384/TLS1.2:ECDHE-ECDSA-CHACHA20-POLY1305-SHA256/TLS1.2:ECDHE-ECDSA-DES-CBC3-SHA/TLS1.0:ECDHE-ECDSA-DES-CBC3-SHA/TLS1.1:ECDHE-ECDSA-DES-CBC3-SHA/TLS1.2
f5-hw_keys                  ECDHE-RSA-AES256-GCM-SHA384/TLS1.2:ECDHE-RSA-AES256-SHA384/TLS1.2:ECDHE-RSA-AES256-CBC-SHA/TLS1.2:DHE-RSA-AES256-GCM-SHA384/TLS1.2:DHE-RSA-AES256-SHA256/TLS1.2:DHE-RSA-AES256-SHA/TLS1.2:ECDH-RSA-AES256-GCM-SHA384/TLS1.2:ECDH-RSA-AES256-SHA384/TLS1.2:ECDH-RSA-AES256-SHA/TLS1.2:AES256-GCM-SHA384/TLS1.2:AES256-SHA256/TLS1.2:AES256-SHA/TLS1.2:ECDHE-RSA-DES-CBC3-SHA/TLS1.2:DHE-RSA-DES-CBC3-SHA/TLS1.2:ECDH-RSA-DES-CBC3-SHA/TLS1.2:DES-CBC3-SHA/TLS1.2:ECDHE-RSA-AES128-GCM-SHA256/TLS1.2:ECDHE-RSA-AES128-SHA256/TLS1.2:ECDHE-RSA-AES128-CBC-SHA/TLS1.2:DHE-RSA-AES128-GCM-SHA256/TLS1.2:DHE-RSA-AES128-SHA256/TLS1.2:DHE-RSA-AES128-SHA/TLS1.2:ECDH-RSA-AES128-GCM-SHA256/TLS1.2:ECDH-RSA-AES128-SHA256/TLS1.2:ECDH-RSA-AES128-SHA/TLS1.2:AES128-GCM-SHA256/TLS1.2:AES128-SHA256/TLS1.2:AES128-SHA/TLS1.2:RC4-SHA/TLS1.2:RC4-MD5/TLS1.2:DHE-RSA-DES-CBC-SHA/TLS1.2:DHE-RSA-CAMELLIA256-SHA/TLS1.2:CAMELLIA256-SHA/TLS1.2:DHE-RSA-CAMELLIA128-SHA/TLS1.2
f5-secure                   ECDHE-RSA-AES128-GCM-SHA256/TLS1.2:ECDHE-RSA-AES128-CBC-SHA/TLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.1:ECDHE-RSA-AES128-CBC-SHA/DTLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.2:ECDHE-RSA-AES128-SHA256/TLS1.2:ECDHE-RSA-AES256-GCM-SHA384/TLS1.2:ECDHE-RSA-AES256-CBC-SHA/TLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.1:ECDHE-RSA-AES256-CBC-SHA/DTLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.2:ECDHE-RSA-AES256-SHA384/TLS1.2:ECDHE-RSA-CHACHA20-POLY1305-SHA256/TLS1.2:AES128-GCM-SHA256/TLS1.2:AES128-SHA/TLS1.0:AES128-SHA/TLS1.1:AES128-SHA/TLS1.2:AES128-SHA/DTLS1.0:AES128-SHA256/TLS1.2:AES256-GCM-SHA384/TLS1.2:AES256-SHA/TLS1.0:AES256-SHA/TLS1.1:AES256-SHA/TLS1.2:AES256-SHA/DTLS1.0:AES256-SHA256/TLS1.2:CAMELLIA128-SHA/TLS1.0:CAMELLIA128-SHA/TLS1.1:CAMELLIA128-SHA/TLS1.2:CAMELLIA256-SHA/TLS1.0:CAMELLIA256-SHA/TLS1.1:CAMELLIA256-SHA/TLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256/TLS1.2:ECDHE-ECDSA-AES128-SHA/TLS1.0:ECDHE-ECDSA-AES128-SHA/TLS1.1:ECDHE-ECDSA-AES128-SHA/TLS1.2:ECDHE-ECDSA-AES128-SHA256/TLS1.2:ECDHE-ECDSA-AES256-GCM-SHA384/TLS1.2:ECDHE-ECDSA-AES256-SHA/TLS1.0:ECDHE-ECDSA-AES256-SHA/TLS1.1:ECDHE-ECDSA-AES256-SHA/TLS1.2:ECDHE-ECDSA-AES256-SHA384/TLS1.2:ECDHE-ECDSA-CHACHA20-POLY1305-SHA256/TLS1.2:TLS13-AES128-GCM-SHA256/TLS1.3:TLS13-AES256-GCM-SHA384/TLS1.3:TLS13-CHACHA20-POLY1305-SHA256/TLS1.3
f5-quic                     TLS13-AES128-GCM-SHA256/TLS1.3:TLS13-AES256-GCM-SHA384/TLS1.3
DHE-RSA-AES128-GCM-SHA256   DHE-RSA-AES128-GCM-SHA256/TLS1.2
DHE-RSA-AES256-GCM-SHA384   DHE-RSA-AES256-GCM-SHA384/TLS1.2
ECDHE-ECDSA-AES128-GCM-SHA256 ECDHE-ECDSA-AES128-GCM-SHA256/TLS1.2
ECDHE-ECDSA-AES256-GCM-SHA384 ECDHE-ECDSA-AES256-GCM-SHA384/TLS1.2
ECDHE-ECDSA-CHACHA20-POLY1305-SHA256 ECDHE-ECDSA-CHACHA20-POLY1305-SHA256/TLS1.2
ECDHE-RSA-AES128-GCM-SHA256 ECDHE-RSA-AES128-GCM-SHA256/TLS1.2
ECDHE-RSA-AES256-GCM-SHA384 ECDHE-RSA-AES256-GCM-SHA384/TLS1.2
ECDHE-RSA-CHACHA20-POLY1305-SHA256 ECDHE-RSA-CHACHA20-POLY1305-SHA256/TLS1.2
The list sys httpd is the GUI part, which maps the settings of configuration utility. You can restrict the ciphers for GUI as well. Since it says All instead of DEFAULT, I’d presume based on the f5 versions openssl library, all the ciphers maybe included. The easy way to test and know would to run a sslscan against the management ip on port 443.
Now coming to cipher suites or cipher group, beginning in v11.6, RC4 is disabled by default due to it’s vulnerabilities. But as mentioned before, if there’s a requirement to have RC4 enabled, one can explicitly mention it. Same way, often organizations make sure explicit disable is mentioned in cipher suites to be positive they are not enabled by mistake too.
Please refer - myF5
If you using “IS-recommend-Cipher” Cipher group, you then got AES & CHACHA20 encryption algo’s, not RC4.
@jaikumar_f5 thank you for your prompt response
