Problem this snippet solves:
iRule to track and display information about traffic from SSL 3.0-only clients. Allows application administrators to assess the impact of disabling access to SSL 3.0-only clients using the BIG-IP.
The iRule logs and displays Source Address, Host header, User-Agent, SSL Cipher and Geolocation (Continent, Country, State)
How to use this snippet:
Enable this iRule on BIG-IP Virtual Server and then access “Magic” URL of “/ssl3lookup/” to display data.
Note that the iRule could be broken into parts so that accessing the data is only possible on an internal Virtual Server.
Code :
# iRule to maintain SSL3-only client information in memory
# For performance purposes, it only "records" client information based on client IP address as a "key" into table
# Rule also will not update information if request is from a client IP addresss that has used SSL3 within the timeout period
# Chad Jenison c.jenison at f5.com
when RULE_INIT {
#set this value to value in seconds you want to keep ssl3clients in memory ; default is 3600 (1 hour)
set static::ttl 3600
set static::honorXffIfExists 1
set static::xffHeaderName "X-Forwarded-For"
if {[SSL::cipher version] eq "SSLv3"}{
if {$static::honorXffIfExists && [HTTP::header exists $static::xffHeaderName]} {
set requestorip [HTTP::header value $static::xffHeaderName]
log local0. "SSL3 connection from Proxy: [IP::client_addr] on behalf of [HTTP::header value $static::xffHeaderName] **Notify Proxy Admin"
set requestorip [IP::client_addr]
if {[table incr -subtable ssl3sourceIPs $requestorip] eq 1}{
table timeout -subtable ssl3sourceIPs $requestorip $static::ttl
table set "ssl3host$requestorip" [HTTP::header "Host"] $static::ttl
table set "ssl3useragent$requestorip" [HTTP::header "User-Agent"] $static::ttl
table set "sslcipher$requestorip" [SSL::cipher name] $static::ttl
log local0. "SSL Cipher Used: [SSL::cipher name]"
table timeout "ssl3host$requestorip" $static::ttl
table timeout "ssl3useragent$requestorip" $static::ttl
table timeout "sslcipher$requestorip" $static::ttl
if {[HTTP::uri] starts_with "/ssl3lookup/"}{
set ssl3clienttable "
| Source IP | Host Header | User-Agent | Geolocation | SSL Cipher Used | HTTP Requests |
| $clientip | [table lookup “ssl3host$clientip”] | [table lookup “ssl3useragent$clientip”] | [table lookup “sslcipher$clientip”] | [whereis $clientip continent]:[whereis $clientip country]:[whereis $clientip state] | [table lookup -subtable ssl3sourceIPs $clientip] |
" HTTP::respond 200 content “$ssl3clienttable” log local0. “Got Magic Request” } }
Tested this on version:
11.6
